How is Rest Mass Affected in the Process of Rocket Propulsion?
SHawking01
A rocket, initially at rest, propels itself in a straight line by giving portions of its mass a constant (backward) speed vout relative to its instantaneous rest frame. (a) Is rest mass conserved in this process? (b) Show that m0du′ = −dm0 vout, where m0 is the rocket’s rest mass and du′ is the change in the rocket’s speed (in its instantaneous rest frame) when its rest mass changes by dm0. (c) Show that m0 du/dm0 = −(1 − u 2/c2) vout, where u is the speed of the rocket in its initial rest frame. (d) Suppose the rocket reaches speed uf relative to its initial rest frame. Show that the ratio of its initial to final rest mass is given by (m0,i/ m0,f)= (c + uf)/( c − uf)c/2vout
Velocity addition formula: u= u'+v/(1+vu'/c2)
a)Rest mass is not conserved due to loss of kinetic energy.
b) m0c2=γ(vout)d\tilde{\m}c2+ γ(du')(m0+dm0)c2
0=γ(du')(m0+dm0)du'-γ(vout)d\tilde{\m}vout
γ(du')=1/√1-(du')2/c2 by the binomial approximation is ≈1.
m0du'=γ(vout)d\tilde{\m}vout
m0du'=-dm0vout
m0/dm0=-vout/du'
c) vout=m0du'/-dm0
I know I have to use the velocity addition formula. How do I find u and u'?
Where is kinetic energy lost?
How do you define (total?) rest mass in the first place?
For (c), I don't think you need velocity addition, the transformation between u' and u (but I don't understand how exactly they are defined) could give the gamma factor without it.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
