Originally posted by Integral
Been thinking about it, and after reading your posts, I think I am seeing my error. First of all if we consider an unanchored rod in a gravity free environment which is delivered a sharp blow to one end, what is the resulting motion?
It seems that the resulting rotation will not be about the cm but the opposite end of the rod, this will result in displacement of the cm therefore translational motion.
Here's my analysis. Let's take the simplest case. A sharp blow is delivered to one end of a thin rigid rod (length 2r; mass m) exactly perpendicular to the rod. Assume the blow imparts an impulse FΔt. What is the resulting motion of the rod?
The motion of any rigid body can be analyzed as a combination of the motion of its center of mass plus its rotation about that center of mass.
The impulse does two things. It imparts a translational momentum, thus giving the cm of the rod a speed v = FΔt/m. It also imparts an angular momentum L = rFΔt. The resulting angular speed about the center of mass is ω = rFΔt/I. Since I = mr
2/3, ω = 3FΔt/mr. The linear speed of the ends (with respect to the center) is ωr = 3v.
Of course, after the impact, the cm will continue in a straight line with constant speed, and the rod will continue to rotate with constant ω.
Immediately after the blow, the motion of the rod can be described as:
- the center moves with speed v (given above)
- the end that was hit moves with speed v + ωr = 4v
- the other end moves with speed v - ωr = -2v
(Of course, hitting the rod at some other angle would result in a different angular momentum and direction of motion.)
Care to derive the equation of motion for this system? I will work on it off line see what I can come up with.
I think the above analysis is correct. Let me know what you find.
