Roller Blades Momentum problem
In summary, the conversation discusses a conservation of momentum problem where a boy on roller blades throws a jug of water, and the resulting velocity gained by the boy is determined to be -2.9 m/s in the opposite direction that he threw the jug in. The conversation also mentions that solving the entire problem is against the rules of the forum.
GodAllen
A boy on roller blades throws a jug of water away from himself, giving it a speed of 14m/s. The boy's mass is 38kg and the mass of he jug and the water is 7.9kg. What is the velocity gained by the lad?
Not sure.
Not sure.
This is a simple conservation of momentum problem, so assume that at the beginning, total momentum is equal to 0
Afterwards, the total momentum must stay the same.
Thus:
Momentum(before) = Momentum(boy) + Momentum(jug)
This should be enough to get you started
so you apply the formula P(before)=P(after). (And by the way the momentum before is 0 as the intial velocities of the boy and the jug are 0 as P(before)= m(boy)xv(boyintial)+m(jug)xv(jug int.))Hope u understood until now.
p(after)=m(boy)xv(boy final)+m(jug)xv(jug)
P(after)=38kg(v)+7.9kg(14m/s)
P(after)=38v+110.6
P(before)=p(after)
0=38v+110.6
38v=-110.6
V=-2.9
So velocity of the boy is 2.9 and its direction is in the opposite direction that he threw the jug in.
Thanks for reading in my answer and i hope u understand and everbody as well since i am a new user.
P(after)=38v+110.6
P(before)=p(after)
0=38v+110.6
38v=-110.6
V=-2.9
you are not supposed to solve the whole problem. this is against pf rules
https://www.physicsforums.com/showthread.php?t=414380
As a scientist, the first step in solving this problem would be to identify the relevant equations and principles that can be applied. In this case, we can use the principle of conservation of momentum, which states that the total momentum of a system remains constant unless acted upon by an external force.
We can also use the equation for momentum, which is mass multiplied by velocity (p=mv).
Based on the given information, we can set up the equation:
Total initial momentum = Total final momentum
(mass of boy x velocity of boy) + (mass of jug and water x velocity of jug and water) = (mass of boy and jug and water x final velocity)
Solving for the final velocity, we get:
(38kg x 0m/s) + (7.9kg x 14m/s) = (38kg + 7.9kg) x final velocity
532.2kgm/s = 45.9kg x final velocity
Dividing both sides by 45.9kg, we get:
final velocity = 532.2kgm/s / 45.9kg = 11.6m/s
Therefore, the boy will gain a velocity of 11.6m/s in the direction opposite to the direction in which he threw the jug of water. This is due to the conservation of momentum, where the momentum of the boy and the jug and water combined is equal to the momentum of the boy after the throw.
1. How does momentum affect roller blade movement?
Momentum is defined as the mass of an object multiplied by its velocity. In the context of roller blades, momentum plays a crucial role in determining the speed and direction of movement. The greater the momentum, the harder it is to change the direction or speed of the roller blades. This is why it is important for skaters to maintain their momentum while performing tricks or turns.
2. What factors can affect the momentum of roller blades?
The momentum of roller blades can be affected by various factors such as the skater's weight, velocity, and the surface they are skating on. The type of wheels and bearings used in the roller blades can also impact its momentum. Additionally, external forces such as friction and air resistance can also affect the momentum of roller blades.
3. How does the conservation of momentum apply to roller blade movement?
The law of conservation of momentum states that the total momentum of a closed system remains constant over time. In the case of roller blades, the momentum of the skater and the blades is conserved as long as there are no external forces acting on them. This means that if a skater pushes off the ground with a certain amount of force, the momentum generated will be transferred to the roller blades, propelling them forward.
4. Can momentum be used to perform tricks on roller blades?
Yes, momentum can be used to perform various tricks on roller blades. For instance, a skater can use their momentum to gain height while performing a jump or use it to maintain balance while spinning. However, it is important to note that controlling and manipulating momentum requires a lot of practice and skill.
5. How can one increase the momentum of roller blades?
The momentum of roller blades can be increased by increasing the velocity of the skater. This can be achieved by either pushing off the ground with more force or using a slope or ramp to gain speed. Additionally, using roller blades with better wheels and bearings can also help increase the momentum. However, it is important to maintain control and balance while increasing momentum to avoid accidents.
