Roller coaster loop searching for Height
The discussion revolves around determining the minimum height required for a mass on a frictionless track to successfully navigate a loop with a radius of 20 meters. The problem involves concepts from energy conservation and centripetal force.
  • Participants explore the application of conservation of energy and centripetal force equations. There is an attempt to derive the minimum height based on these principles, with some questioning the assumptions made regarding the height of the loop and the forces acting on the mass.
Some participants have provided guidance on the correct application of centripetal force and energy conservation, while others are reconsidering their initial calculations and assumptions about the height needed to complete the loop. Multiple interpretations of the problem are being discussed, with no explicit consensus reached yet.
There is confusion regarding the relationship between the height of the track and the height of the loop, as well as the conditions at the top of the loop where the mass must maintain contact with the track. Participants are also addressing the implications of gravitational acceleration in their calculations.
gggorillaz
A mass of 100kg is h meters high on a track that extends into a loop that has a radius of 20m. Assume track is frictionless. I need to find minimum height for the mass to make it around the loop without falling off or going backwards.
Conservation of Energy:
K_1+U_2=K_2+U_2
v=sqrt(2gh)
Force:
F=ma
F=mg
Centripetal Force:
(mv^2)/r=F
This may be right, i only need someone to check my work in case I am incorrect. So, from K_1+U_1=K_2+U_2 i get K=U
From there i have 1/2mv^2=mgh
masses cancel so v^2=2gh
from there i find centripetal force = (mv^2)/r=F
F=mg=(mv^2)/r
masses again cancel so i find that g=(v^2)/r
I replace v^2 with 2gh so i find that g=2gh/r
g's cancel so i find that h=r/2 plug in for r: h = 20/2=10meters.
Can someone verify that I am correct? thanks in advance!
K_1+U_2=K_2+U_2
v=sqrt(2gh)
Force:
F=ma
F=mg
Centripetal Force:
(mv^2)/r=F
F=mg=(mv^2)/r
You are not correct, how can the track be only 10 m high when the loop itself is 40 m high?:wink: Can you spot your error in your equation in the use of the variable 'h' in relation to the height of the top of the loop where the speed is critically at its minimum?
iIs it that i have a skewed understanding of what centripetal force equals? maybe that ma=mv^2/r but my a isn't = g in this case?
Should i be getting h=2diameter? if so, how do i get there?
I am not sure of your understanding of the centripetal force, but when you solved for the acceleration of a =g, that is correct, at the top of the loop, since at that point, there is no normal force acting if the coaster is just able to round the top of the loop without leaving the track. You may have assumed that a=g at the bottom of the loop?? Anyway, since v2 = rg is correct at the point at the top of the loop, then when applying conservation of energy , you must apply it between the point h and the point at the top of the loop, to equate velocities and solve for the distance from the top of the track to the top of the loop.
Ohhh right, I see now, it would now be mgh=1/2mv^2+mg(height of loop) so h=1/2(r)+h =1/2(20)+40 = 50m right?
gggorillaz said:
Ohhh right, I see now, it would now be mgh=1/2mv^2+mg(height of loop) so htrack[/color]=1/2(r)+hloop[/color] =1/2(20)+40 = 50m right?
Right:approve:
Yay! thank you so much for helping!
  • · Replies 16 ·
