Roller coaster loop cart velocity
The discussion focuses on calculating the velocity of a roller coaster cart at point A after being dropped from a height of 120m, resulting in a speed of approximately 48.99 m/s. Participants debate the concept of reaction force at point B, clarifying that the normal force acts as the reaction force between the passenger and the seat. The conversation also addresses the acceleration of the cart from points A to C, emphasizing the use of kinematics to determine this value based on known velocity and distance. The importance of applying Newton's second law is highlighted for understanding forces in motion. Overall, the thread explores key physics principles related to roller coaster dynamics.
raffish
in an amusement park ride a cart of mass 300kg and carring four passangers each of mass 60kg is dropped from a vertical height of 120m alonga path that leads into a loop-the-loop machine of radius 30m. The cart then enters a straight stretch from A to C where friction brings it to rest after a distance of 40m. (see attachment)
a) find the velocity of the cart at A
answer: mgh = (1/2)mv²
540 x 10 x 120 = (1/2) x 540 x v²
Thus, v = 48.99 m/s
b) find the reaction force from the seat of the cart onto a passanger at B.
answer: well at the top the net force will be euqual to the weight and the normal force, but what reaction force are they talking about here. i mean there isn't any force pushing onto the seat is there?
c) what is the acceleration experienced by the cart from A to C (assumed constant)?
answer: ?
The "reaction force" is the normal force. Of course there's a force pushing onto the seat--person and seat push against each other: that's the "normal" force. (Unless the speed is just right so that no normal force is needed to make it around the curve.) You'll need to apply Newton's 2nd law to solve for this force.
answer: ?
Use kinematics--you have the velocity and the distance, use them to find the acceleration. (Depending upon the kinematic equations at your disposal, this can be done in one step or two.)
