Verifying Rolle's Theorem on f(x)=cos 5x, [π/20, 7π/20]
  • Thread starter Thread starter HHenderson90
    Theorem
HHenderson90
Verify that the function satisfies the three hypotheses of Rolle's Theorem on the given interval. Then find all numbers c that satisfy the conclusion of Rolle's Theorem. (Enter your answers as a comma-separated list.)
f(x) = cos 5x, [π/20, 7π/20]
Rolles Theorem states:
Let f be a function that satisfies the following three hypotheses:
1. f is continuous on the closed interval [a,b]
2. f is differentiable on the open interval (a,b)
3. f(a)=f(b)
Then there is a number c in (a,b) such that f'(c)=0
1. F is continuous on the closed interval because there is no where on the interval that f(x) is undefined.
2. f is differentiable on the open interval because it is continuous on the closed interval
3. This is where I get confused, these are not a part of the unit circle, do I just plug them into the calculator to determine that f(a)=f(b)?
Then, to find C I must first find the derivative-
f(x)=cos5x
f'(x)=-5sin5x
then I set this equal to 0 to find c
0=-5sin5x
so f'(x)= 0 when x is 0, when the sin5x=0. I don't even know how to go about finding this with numbers that are not on the unit circle.
First off, 2 isn't entirely correct - there are functions which are continuous but not differentiable (e.g. absolute value).
As for the third part, it might be easier to make a change of variables: y = 5x. Then you're looking at cos y. What's the interval this would be on? It'd be [5*(pi/20), 5*(7 pi/20)] = [pi/4, 7 pi/4] (note that 8 pi/4 = 2 pi, so you're close)
As for finding C, you're almost there. sin 5x = 0 is the correct equation. When is sin y = 0? How does that translate into x?
So I am looking for a value between [pi/4, 7pi/4] rather than [pi/20,7pi/20]?
This makes sense and I understand that.
As for finding C, sin y= 0 at pi/2 and 3pi/2. I'm not sure how to translate this into x. I thought I would have to multiply it by 5 in order to translate it into x getting 5pi/2 and 15pi/2, but this was wrong. I then looked again and thought I realized my error and divided by 5 instead, getting pi/10 and 3pi/10, and I was still wrong. Where is my error translating this into x?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
