High School Rolling of non-deforming sphere on a non-deforming rough surface?
The discussion centers on the dynamics of a non-deforming sphere rolling on a non-deforming rough surface, specifically examining the conditions under which static friction (rolling friction) acts on the sphere. It is established that when the sphere is given a translational velocity v and an angular velocity w such that v=Rw, static friction does not apply unless an external force is introduced. The concept of rolling resistance, defined as the counter torque due to deformation, is also clarified, although it is not present in this idealized scenario. The participants debate the nature of friction, concluding that it only arises in response to external forces acting on the object.
  • Understanding of Newton's laws of motion
  • Familiarity with concepts of static friction and rolling friction
  • Knowledge of angular velocity and translational velocity
  • Basic principles of torque and rolling resistance
  • Explore the mathematical modeling of rolling friction in rigid body dynamics
  • Study the effects of external forces on rolling motion in real-world scenarios
  • Investigate the differences between static and kinetic friction in various materials
  • Learn about the implications of rolling resistance in mechanical engineering applications
Physics students, mechanical engineers, and anyone interested in the principles of motion and friction in rigid bodies will benefit from this discussion.
tbn032
According to my current understanding
rolling friction
rolling friction is the static friction (parallel to the surface on which the object is moving) applied by the frictional surface (rough surface) on the contact point or contact area of the object whose v≠Rw(v is translational velocity and R is radius of sphere and w in angular velocity).It increases the angular acceleration and decreases the translational velocity or vice versa till the condition v=Rw is reached.
Rolling resistance
Rolling resistance is the counter torque provided to the rolling object due to the deformation of the object or the surface, causing the normal forces to shift from the centre of mass and thus providing counter torque.
Now my question is.
Suppose a non deforming sphere of radius R initially is kept on a non deforming rough horizontal surface(frictional surface). Then it is provided with translation velocity v and angular velocity w such that v=Rw.will the static frictional force(rolling friction) be applied on the sphere?will the sphere continue to roll forever?(there is no air resistance and there is no rolling resistance due to non deforming sphere and non deforming horizontal surface)(gravitational forces acts on the sphere perpendicular to the horizontal surface)
tbn032 said:
Now my question is.
Just like it happens between two flat surfaces, friction force only appears as a reaction to another force.
If nothing is pushing or pulling your sphere in the rolling direction, there is no acceleration or related forces.
I think friction could appear in the absence of a force. Suppose a cube is sliding on a frictional horizontal surface with momentum p(no external force is being applied on the cube). Friction would still be applied on the cube(opposing the motion of the cube), and thus the cube will stop sliding.
rolling friction
Rolling resistance
Now my question is.
I thought you asked this question already. Friction applies in real scenarios. If you invent a hypothetical scenario, then there's no way to test whether there is friction or not.
Whether there is friction is part of the hypothetical assumptions.
I was referring to static friction at each instant the contact point of the sphere is in static contact with the perfecly flat surface.
But I believe that my previous statement is also valid for the case of the sliding cube, as Newton’s laws still apply: a change in momentum during certain time always generates a force that resists that change, and forces always come in pairs.
Thread 'A high school physics problem demonstrating relative motion'
I remembered a pretty high school problem from kinematics. But it seems it can help even undergraduates to develop their understanding of what a relative motion is. Consider a railway circle of radius ##r##. Assume that a carriage running along this circle has a speed ##v##. See the picture. A fly ##M## flies in the opposite direction and has a speed ##u,\quad |OM|=b##. Find a speed of the fly relative to the carriage. The obvious incorrect answer is ##u+v## while the correct answer is...
  • · Replies 37 ·
  • · Replies 22 ·
