Root vs. ratio in determining radius of convergence of a power series
The discussion revolves around the methods for determining the radius of convergence of power series, specifically comparing the ratio test and the root test. Participants explore when to use each method and the implications of their results.
  • Technical explanation, Conceptual clarification, Debate/contested, Homework-related
  • One participant questions the interchangeability of the ratio and root tests for determining the radius of convergence, noting that the ratio test is often recommended for series involving factorials.
  • Another participant suggests that both tests are valid and proven, but the ease of use may depend on the specific form of the coefficients in the series.
  • A participant shares a specific example of a power series and indicates a preference for using the ratio test in that case.
  • There is a mention of confusion arising from obtaining different results using the two tests, which one participant resolves by identifying an error in their application.
  • One participant confirms that the radius of convergence for the provided example is 1, but emphasizes that this does not provide information about convergence at the boundary points where |x|=1.
Participants generally agree that both tests can be used to determine the radius of convergence, but there is no consensus on their interchangeability or the best contexts for their application. Some express confusion over differing results from the tests.
Participants note that the results from the ratio and root tests may vary based on the specific series being analyzed, and that additional checks are necessary for convergence at the boundary of the radius.
Students and individuals studying power series and convergence in mathematics, particularly those seeking clarification on the application of convergence tests.
brush
Hi everyone :smile:
When determining the radius of convergence of a power series, when should I use the ratio (a[sub n+1] / a[sub n]) test versus the root (|a[sub n]|^(1/n)) test?
I know that I'm supposed to use the ratio only when there are factorials, but other than that, are these tests basically interchangeable?
Also, are there any differences in usage/application of the tests in the context of determining the radius of convergence of a power series?
Thanks
So, for instance, how do I determine the radius of convergence of:
[tex]\sum^{\infty}_{n=0}\left(\frac{x^{n}}{n^{2}+1}\right)[/tex]
Thanks again :smile:
Hi brush!
Both the ratio and the root test "work" in all cases (they are proven theorems), but which one is easier to use depends on the concrete form of the a_n. The ratio test is probably used more often then the root test.
In your particular example, try the ratio test. :wink:
Thank you for the reply, yyat! :smile:
The confusion I was having was because I kept getting different results from the ratio and root test, but I have figured out what I was doing wrong.
In the case above, both the root and ratio tests should yield (I think):
[tex]\left|x\right| = 1[/tex]
Yes, the radius of convergence is 1, that means the series converges for |x|<1. Note though that this tells you nothing about convergence at points with |x|=1, that needs to be checked separately.
  • · Replies 19 ·
