Roots and coeffecients of polynomial equations
  • Thread starter Thread starter olee
    Polynomial Roots
The discussion revolves around solving the polynomial equation 2x² - kx + k = 0, given that one root is twice the other. Participants suggest substituting the roots r and 2r into the equation to create two simultaneous equations in terms of r and k. The conversation highlights the importance of simplifying the equation and checking results against the original problem. Ultimately, through various substitutions and calculations, it is concluded that k can equal 9 or 0, with the latter being invalid as k cannot be zero. The key takeaway is the method of substituting roots to derive relationships between the variables in polynomial equations.
olee
One root of 2x2-kx+k=0 is twice the other. Find K. (assume k is not 0)
not sure what this means.
\alpha+\beta=\frac{-b}{a}
\alpha\beta=\frac{c}{a}
then i tried
\alpha=2\beta then substituted in..
2x2-3\beta+\alpha\beta=0 and now I am stuck
im not sure if this is right way to do this
Let r and 2r be the two roots. Substitute each one in your equation. That will give you two equations in two unknowns - r and k. Solve the two equations simulataneously for these variables.
thanks for reply. which equation are you mentioning?
The only equation you were given, and the one whose roots you are trying to find.
2x2 - kx + k=0
2x2 - kx + k=0
thanks for reply. but i still have two unknowns and i can't solve
edit: and i still have the x at the start of that equation. all i know is 'a' (which is 2)
You should have two equations in the two unknowns. Solve these equation simultaneously to find r and k.
by substituting in, do you mean where the -k is (which is b) i substitute in 2r+4r? (to get this i had r+2r = -\frac{b}{2})
and then where the +k is (which is c) i substitute in 4r2? (to get this i rearranged 2r2=\frac{c}{2}
olee said:
by substituting in, do you mean where the -k is (which is b) i substitute in 2r+4r? (to get this i had r+2r = -\frac{b}{2} )
edit: was to remote the extra bracket
What I'm saying is that you should ignore the equations you have with alpha and beta and a and b, and focus on the equation you're trying to solve, 2x2 - kx + k = 0.
You are given that r and 2r are roots of this equation, so if you replace x by r you'll get one equation, and replace x by 2r, you'll get another equation. These two equations will be in terms of r and k.
Solve those two equations simultaneously for r and k.
You got the equation
In the 2nd term here you have used the information you are given (one root is twice the other) and in the third term you haven't yet.
Oh, and you must have meant
2x2- 3\beta x + \alpha\beta=0
thanks for reply. doing this way i made the two equations equal each other (2r2-kr+k = 8r2-2kr+k
ended up with r=\frac{6}{k} and i can't solve that because of two unknown variables.
thanks for reply. this method i ended up with 2x2-3\betax+2\beta2
I get r = k/6 (not 6/k) or r = 0.
If r = 0, then 2r = 0, so what is k?
If r = k/6, then 2r = k/3, so what is k?
thanks for reply. yeah i got r=k/6 (i mistyped)
If r = 0, then 2r = 0, so what is k? k=0
If r = k/6, then 2r = k/3, so what is k? plugged r=k/6 back into original equation and got k = 9 or 0.. right?
EDIT: made a mistake, recalculated and got 9 and 0
Sorry -I made a typo.
It is usually less confusing to work with an equation whose leading coefficient is 1. So better to divide your initial equation by 2. So use
x2 - kx/2 + k/2
A quadratic with one root twice the other is
x2-3\betax+2\beta2
I think you had the idea of that but the leading coefficient caused you confusion. You should easily be able to see your last result must be wrong; do not accept any reult without checking it against your original problem.
x2 - kx/2 + k/2
x2-3\betax+2\beta2
so how do i solve it from here? I am really confused..
Any, in other words every, quadratic with one root twice the other is of form
x^2-3\beta x+2\beta^2 (1)
(a result you got but for a little mistake.)
You are told
x^2 - \frac{kx}{2} + \frac{k}{2} (2)
is a quadratic with one root twice the other.
So (2) must be of form (1). Or if you like identical to it for all x. So do you see how to compare them (remembering similar exercises you've probably done before for identical expressions)?
