Rope Tension in Static Equilibrium
A 25kg weight is suspended from a rope wrapped around a pulley, creating angles of 41 degrees and 69.5 degrees with the walls. The equilibrium equations used are EFx=0 and EFy=0, leading to calculations for the tension in both ropes. The calculated tension in rope A is 246N, while the tension in rope B is 172N. The discussion emphasizes the importance of providing clear equations and values for verification. A suggestion is made to draw a free body diagram to better visualize the forces involved.
semme
A hanging weight with a mass of 25kg is suspended from a rope from a wall. The rope with the weight is wrapped around a pully which is also attached to a different wall. The angle that rope a(rope with mass) makes with the wall is 41 degrees, and the angle of the other rope with the other wall is 69.5 degrees. Find the force of tension in each rope.
EFx=0
Efy=o
EFx=0
Acos(49)-Bcos(20.5)=0
A=Bcos(20.5)/cos(49)
EFy=0
Asin(49)+Bsin(20.5)=mg
(Bcos(20.5)/cos(49))sin(49)+Bsin(20.5)=mg
B=172N
Substitute B back into A
A=172cos(20.5)/cos(49)
A=246
I got the force of tension in A to be 246N and the tension in B to be 172N. Is this correct or am I making this to easy? Also is it just a conicedence that the tension on the rope with the weight is the force of gravity?
Thanks for your help.
Looks good to me, although next time, please provide equations and values you have calculated. It's a lot easier to check your calculations than do them ourselves!
Oh, now youve added the picture.. it's not what I thought! I'd imagined both ropes attached to the mass, and the pulley on the left hand wall (for some reason!) Should still be right though.. just draw a free body diagram at the point at which rope A meets rope B and set up the equations from there.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
