Rotary Mechanical Brake System
A user is exploring braking systems to limit the rotational speed of a platform with a fixed vertical shaft and a rotating outer tube, facing challenges due to the mass of over 200kg and a target speed of 1 RPM. Traditional braking methods like band or friction brakes are deemed ineffective, leading to consideration of rotary dampers and electronically assisted brakes, though safety concerns exist. Suggestions include researching eddy brakes and magnetic braking systems, which could provide smoother deceleration. The discussion also touches on the importance of the platform's mass and the need for simple, calculable solutions. The need for clarity on the power source and the potential RPM without brakes is emphasized to refine the braking approach.
Jameseyboy
Hi,
I am looking into a braking system which can limit the rotational speed of a platform; the assembly consists of a fixed vertical shaft and a rotating outer tube (seated with bearings). The platform diameter is >5 times larger than the tube.
I have looked into the typical band brake, friction brake, etc however, there is a problem:
The limit on rotational speed is set at 1 RPM, so to generate a relevant braking force centrifugally is unrealistic (considering the mass is over 200kg).
The only concern with electronically assisted brakes is the safety factor.
My only other option would be rotary dampers but if anyone has any better ideas, that would be great.
Cheers!
What's the function of the design and how integral to the function is the 200kg's? I'm thinking of some of the recent engine flywheel designs where the constant mass of the flywheel has been replaced by a magnetically induced mass. With this design you can brake at a different mass then the operational mass.
The 200kg is basically the mass of the plate + its loaded elements.
Are you talking about eddy brakes? I understand they can be calibrated such that they are applied at a particular speed and effectively maintaining it.
I am going to need to back everything up with calculations so the simpler the better.
I would keep the brakes as simple and uncomplicated as possible since you have not yet identified a function for the device. What would the weight of the tube be if it was made of carbon fiber?
For the magnetics look first at trains that run by levitation. Do a search for magnetic flywheels and the internal combustion engine.
When the disc rotational speed reaches 1 RPM, it needs to be capped but with smooth deceleration.
The materials are steel and cannot be changed. I'll do some more research on magnetic brakes. I do have a little room to play with; my shaft is around 5cm radius, and my inner tube is around 16cm radius.
Cheers
What is causing the platform to rotate ?
Likes Work Hard Play Hard
Fair enough but that's not where I was going with my response. Your braking difficulties are due to the mass of the tube. If you can't change the tube is the tube on a clutch? What's the power source? Is brake dampening required?
Cheers
Is 1 RPM a hard limit, such that transient overshoot to 1.01 would be a disaster?
It is not clear whether you are asking about a breaking mechanism of about the control system to apply the brake.
I see you edited your original question which raises even more.
As already asked what is powering the platform rotation? What's the potential RPM of the platform without the brake? Is it safe to assume your goal is to use a brake as a governor? If so, does the governor have to be a brake?
