How does Faraday's Law apply to a rotating coil in a magnetic field?
trix312
A flat square coil of N turrns and area A is rotated at an angular velocity w in a uniform magnetic field of strength B. The rotation axis is perpendicular to the magnetic field direction. The coil is connected to a Galvonometer using suitable slip ring connectors and the total resistance in the coil and meter is R. Show that the detected current is I = -NBAcos(wt) / R
Fardays 's law of induction *N
I = V/R
I get I = NBAwsin(wt) / R
I don't see why i am wrong. The B field and area is uniform. So I only differentiate cos(wt) and divide the emf by R to obtain the current.
Any help or suggestions would be very welcome.
Both answers can be right, depending on the orientation of the coil at time t=0. Since this isn't given in the problem, all you can say is that I ~ Cos[w(t+t0)]. If t0 = 0, you get a Cos solution, if t0=-pi/(2w), you get a Sin solution, and if t0 is something else, you get something in between.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
