Angular Motion: Solving for Velocity & Acceleration
A wheel with a diameter of 1 meter is rotating clockwise at an angular speed of 115 rpm and an angular acceleration of 18 rad/s². To find the angular velocity after 6 seconds, the calculation yields approximately 117.86 rpm, noting the importance of indicating direction as clockwise. The tangential velocity at this point can be determined by multiplying the radius by the angular velocity. The resultant acceleration at the rim is the vector sum of tangential and centripetal accelerations. Understanding the direction of angular velocity is crucial, with clockwise considered negative in this context.
Kevin1199959
A wheel 1m in diameter is rotating on a horizontal plane in the clockwise direction with an angular speed of 115 rpm. It's angular acceleration is 18 rad/s2
A) What is the angular velocity (magnitude and direction) after 6 seconds
B) What is the tangential velocity of a point on the rim of the wheel at 6 seconds
C) What is the resultant acceleration of a point on the rim at 6 seconds
2pie ; 1 rev
I don't know how to find the answer
Hi Kevin1199959! :smile:
(have a pi: π :wink:)
You can use the same constant acceleration equations as for linear motion.
And linear displacement speed and acceleration are r times the angular version. :smile:
(have a pi: :wink:)
Lol, thanks again :P Btw, where do you get the signs from? So that you won't have to give them to me every time...
Soo;
A) 18*6/2π+115 = 117.86 rpm? But it sais magnitude and direction... do i actually have to give a direction?
B) r*117.86= 117.86 revolutions = tangential velocity?
C) ?!?
Please elaborate... I'm really lost!
The angular velocity is a vector* that is perpendicular to the direction of rotation (see the first image on Wikipedia's article: http://en.wikipedia.org/wiki/Angular_velocity)
You can use a sort of right hand rule to find the direction; curl your hand in the direction of rotation and then the vector points along your thumb. *technically a pseudovector, but let's forget about that...
I'm still lost... can you please explain what i have to do?! Can you give me an example of an answer at least?
Hi Kevin1199959!
(just got up :zzz: …)
How did you get 117.86? :confused: (and you only need 3 significant figures anyway)
The way I remember the direction is that anti-clockwise is positive, so the angular velocity is up for anti-clockwise, and down for clockwise.
Ah, perhaps I should have specified …
And linear displacement speed and acceleration are r times the angular version, measured in radians. :wink:
C) ?!?
The "resultant acceleration" is the vector sum of the tangential acceleration and the centripetal acceleration
On a Mac :approve:, you just type them! :-p … for example, µ is alt-m.
On a PC :frown:, the only thing you can do is to copy them into a text document for future pasting. :smile:
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
