Rotation of Axes: Point (x,y) to (X,Y)
  • Thread starter Thread starter atavistic
    Axes Rotation
When the coordinate axes are rotated clockwise by an angle theta, the coordinates of the new point (X,Y) can be determined using trigonometric functions. A visual representation includes the original point (x,y) on the standard axes and the new axes positioned at angle theta. By drawing perpendiculars from the point to both the original and rotated axes, two right triangles are formed. The lengths of these perpendiculars can be expressed in terms of x, y, and theta, allowing for the calculation of y' as a function of these variables. This method effectively illustrates the transformation of coordinates due to axis rotation.
atavistic
Let a point be(x,y)
If the coordinate axes are shifted in clockwise direction by an angle theeta,what are the coordinate of the new point(X,Y).
How about drawing a picture. Draw the x-axis horizontal, the y-axis vertical and mark the point (x,y). Now draw the x'-axis at angle \theta to the x-axis, y'-axis at angle \theta to the y-axis. Draw a perpendicular to the x-axis. Its length is y. Draw a perpendicular to the x'-axis. Its length is y'. You now have two right triangles and should be able to use trig functions to deternine y' as a function of x, y, and \theta.
