Rotational Equilibrium and Dynamics Question
The discussion focuses on a physics problem involving a uniform ladder resting against a wall, specifically question number 62 from a provided link. The ladder is 8.00 m long, weighs 200.0 N, and has a coefficient of static friction of 0.600, with a 50-degree angle to the ground. Participants suggest summing moments about specific points to eliminate variables and determine the forces acting on the ladder. The goal is to find how far an 800.0 N person can climb before the ladder slips. The approach involves calculating tensions and forces systematically to solve the problem.
ryomaechizen
1) If you go to this site it has the question already set up. the one I need help on is question number 62, the picture frame one. I know that the answers are already given but I want to know how this is set up.
http://www.phys.uvic.ca/vannetten/phys102/Assignments/t1a9p.pdf
2) A uniform ladder 8.00 m long and weighing 200.0 N rests against a smooth wall. The coefficient of static friction between the ladder and the ground is 0.600, and the ladder makes a 50 degree angle withthe ground. How far up th eladder can an 800.0 N person climb before the ladder begins to slip?
Thanks in advance
Sum the moments about the line passing through T2 and P (This will eliminate both), this will give you the tension for T1. Now Sum moments at the line through T2 and T1 to find P (this will eliminate T2 and T1), and then sum forcess to find P.
