Rotational motion and finding the moment of inertia
The discussion revolves around calculating the moment of inertia (I) of a ball rolling down a slope using conservation of energy principles. The user initially struggles with finding angular velocity (omega) but correctly determines it by dividing linear velocity by the ball's radius, resulting in an angular velocity of 266.667 rad/s. After calculating I as 1.94 x 10^-5 kg/m^2, another participant points out that this value suggests a discrepancy with standard moment of inertia formulas for solid and hollow spheres. The conversation concludes with acknowledgment of a potential error in the exercise's parameters, emphasizing the importance of verifying calculations against established physics principles.
Bolter
Find the moment of inertia
PE = mgh
KE tran = 1/2mv^2
Here is the problem that I am finding difficult to answer
I had tried using conservation of energy to do this question
Where I know that the gravitational potential energy at the top of the slope equals to the sum of both the linear and rotational kinetic energy at the bottom of the slope.
Hence which is why I written down this, in where I then rearrange for I (moment of inertia). However upon doing this, I realize I have an unknown which is omega (angular velocity). How would I work out omega so I then find the moment of inertia of the ball?
Thank you!
You make use of the given that 'the ball rolled' (i.e. it did not slip) !
So is finding angular velocity as simple as dividing the linear velocity by the ball's radius
I have done that to get my angular velocity to be 266.667 rad/s
Then plugging in all the values I need from before, I get I = 1.94 x 10^-5 kg/m^2 (3 sig figs)
Is this alright?
Is this alright?
Looks right.
haruspex said:
Looks right.
Thanks for checking. Appreciate it!
I agree with your result. There is one snag, however:
For a massive sphere, ##I = {2\over 5}\,mr^2##; for a hollow sphere, ##I = {2\over 3}\,mr^2##. Most you can have is ##I = mr^2## (all the mass at distance ##r##, like for a ring).
Our ##I = 1.94 \ 10^{-5}## kg m2 would be 1.15 ##mr^2\qquad## o0)
I suspect an error by the exercise composer ...
Likes Bolter
Ah yes that is true. I’ll definitely take note of that :)
