Rotational Motion and speed of a disc
A 36.5-cm diameter disk rotates with a constant angular acceleration of 2.00 rad/s², starting from rest. At t = 2.30 s, the angular speed is calculated to be 4.6 rad/s, while the linear velocity at point P on the rim is approximately 0.8395 m/s, and the tangential acceleration is 0.365 m/s². The position of point P relative to the positive x-axis is determined to be 0.39° after converting from radians. There was a discussion about the initial angular displacement, clarifying that it should be zero since the disk starts from rest. The direction of angular acceleration is noted to affect the final angle with respect to the x-axis.
nbroyle1
A 36.5-cm diameter disk rotates with a constant angular acceleration of 2.00 rad/s2. It starts from rest at t = 0, and a line drawn from the center of the disk to a point P on the rim of the disk makes an angle of 57.3° with the positive x-axis at this time.
(a) Find the angular speed of the wheel at t = 2.30 s.
(b) Find the linear velocity and tangential acceleration of P at t = 2.30 s.
(c) Find the position of P (in degrees, with respect to the positive x-axis) at t = 2.30s.
(a) to solve for angular speed W=at or W=(2)(2.3) and got 4.6m/s
(b) first I calculated the radius by multiplying 36.5*.01 then dividing by 2 and got .1825.
next I plugged it into V=(.1825)(4.6) to solve for linear velocity and got .8395.
To get tangential acceleration I used A=(.1825)(2) and got .365.
(c) θ=1+.5(2)(2.3)^2 and got 6.29 radians which I converted to degrees and got 360.39 and subtracted 360 to get position with respect to positive x-axis.
Not sure If I did part this right can I get some verification??
Well ... why u added 1 to θ in the (c) part ?
the formula simply says-
θ=ωot + αt2
and ωo is initial rotational velocity... and since disk was at rest at t=0 so ωo = 0
rest all is correct.
The reason I did that in part c was because I subtracted θo to the right side of the equation. I thought the initial angular displacement would be 1 since it is one radian.
I meant I added it to the right side of the equation oops
... sorry ... yes ... you are correct .
even i meant Δθ by θ.
and yes ... your answer is correct.
ok thanks
yes ... but the direction of angular acceleration will make a difference, if its clockwise or anticlockwise, the final angle with the x-axis would be different in the two cases.
