Rotational motion and tangential speed?
To determine the maximum speed of a 919 kg rollercoaster on a circular track with a diameter of 16.21 m without leaving the track, the balance of forces must be analyzed. A free-body diagram illustrates that the gravitational force must equal the required centripetal force at the highest point of the track. The centripetal force is dependent on the tangential velocity, which can be calculated using the formula F=ma. The discussion emphasizes that while gravity varies with the angle, it can be simplified for introductory physics problems. Understanding the relationship between gravitational force and centripetal acceleration is crucial for solving this problem.
yramos9
A 919 kg rollercoaster is about to go up a hill that acts as the top of a circle 16.21m in diameter. What is the fastest that car can move (in m/s) without leaving a track?
known:
mass: 919 kg
diameter: 16.21
radius: 8.105
Vt=r\omega
\omega=\theta/time
i have no idea how to work this out without knowing the time or speed or somekind of time measurement. Is there another way to solve this?
centrifugal force
force balance
free body diagram
huh??
Draw a free-body diagram of the cart with centrifugal force pulling it up and gravity pulling it down. The sum of the forces on the cart should be zero in the radial direction (since that's the direction for which you don't want motion). Centrifugal force should be a function of tangential velocity, which is the velocity in question.
What level of physics is this? Gravity would realistically be a function of the angle about the center of the circle and only be exactly g when the cart is exactly on the tip of the half-circle. But you could probably neglect this if it's an introductory physics course.
this is 11th grage physics pre-ap.. i don't think I've learned what youre trying to teach me.
When gravity can provide the centripetal acceleration required to keep the roller coaster on the track, the coaster doesn't fly off. Otherwise, it does. When does gravity exactly equal the required centripetal force? (Hint: F=ma)
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
