Rotational motion (confused about the variables)
The discussion clarifies the distinctions between various types of acceleration in rotational motion. Linear acceleration is the vector that affects both speed and direction, comprising centripetal acceleration, which directs towards the center without changing speed, and tangential acceleration, which increases speed. Angular acceleration, on the other hand, measures the rate of change of angular speed and is distinct from centripetal acceleration, which pertains to linear velocity changes. While centripetal acceleration can exist at constant speed, angular acceleration will be zero in such cases. The conversation also touches on angular velocity as a vector that combines magnitude and direction, complicating the understanding when considering three-dimensional motion.
madah12
we have many accelerations in rotational motion ,and I don't know the difference between them. first the linear acceleration which as I understand is the vector acceleration which has the same direction as the change of velocity and it affects the speed and direction then it's two components are centripetal acceleration which changes the angle and is towards the center and it doesn't change the magnitue of the velocity. Then there is the tangential acceleration which is perpendicular to the centripetal acceleration and it increases the magnitude of the velocity.
First is my understanding of the acceleration correct ? second I also see that we have the angular acceleration and it changes the the the angular velocity but this confuses me what is the difference between it and the centripetal acceleration? they both change the angle.
Here's how I'd put it. Something moving in a circle has a linear (or translational) acceleration. That acceleration has two components: a centripetal component and a tangential component.
What is usually called the angular acceleration is the rate of change of angular speed. The angular speed relates to the tangential speed via: ω = r*vt. In turn, the angular acceleration relates to the tangential acceleration via: α = r*at.
Does that help?
but what I don't understand is whether the centripetal acceleration and the angular acceleration are measuring the same thing or not? I mean they all affect the change of the direction of the velocity right?
No. Centripetal acceleration is the rate of change in linear velocity (for constant speed). Angular acceleration is the rate of change of the angular speed. For something moving with constant speed, there will be a non-zero centripetal acceleration while the angular acceleration will be zero.
oh thanks I see it now but if angular acceleration is the rate of change of angular speed then what is the rate of change of angular velocity?
As long as the axis of rotation doesn't change, as when you stick to two dimensions, angular speed and velocity are the same (for practical purposes). When you deal in three dimensions, and the axis of rotation can change, things get complicated fast. Angular velocity is a vector (pseudovector, really) whose magnitude is the angular speed and whose direction is along the axis of rotation. See: http://en.wikipedia.org/wiki/Angular_velocity"
but isn't the rotation negative if it is clockwise?
That's the convention, sure.
