Rotational Motion dynamics problem
The problem involves a giant yo-yo of mass 400 kg and radius 1.2 m dropped from a height of 63 m, with the axle radius being 0.1 m. The initial calculations for acceleration and velocity were based on incorrect assumptions about the radius used in the moment of inertia and torque equations. The correct approach requires distinguishing between the yo-yo's overall radius and the axle radius when applying the equations of motion. The acceleration should be recalculated using the proper radius for torque, which affects the final velocity. Clarifying these details is crucial for obtaining the correct answer for the velocity of descent.
miamirulz29
A giant yo-yo of mass 400 kg measuring about 1.2 m in radius was dropped from a platform 63 m high. One end of the string was tied to the platform, so the yo-yo unwinds as it descended. Assuming that the axle of the yo-yo has a radius of .1 m, find the velocity of descent at the end of the fall. the acceleration of gravity is 9.81. Answer in units of m/s.
F = ma
Tau = I * alpha
I = mr^2/2
mg-T = ma
rT = I * alpha
I solved for a and got a = 2g/3.
I then used that acceleration to find how the time it took to descend.
x = .5at^2, x being the height of the platform.
Once I found t, I found v using:
v = at.
The answer I got was incorrect. Could somebody please tell me what I am doing incorrectly? Thanks in advance.
miamirulz29 said:
F = ma
Tau = I * alpha
I = mr^2/2
mg-T = ma
rT = I * alpha
I'm not quite sure where you got your expression for a, but I came up with something much smaller.
A possible bit of advice is to take care with the fact that there are two 'r's involved.
  • There's the 1.2 m radius of the entire yo-yo. This is important when calculating the yo-yo's moment of inertia, I.
  • Then there is the 0.1 m radius of the axle. This is the one to use when torques and such are involved, like τ = Iα (where τ is the torque).
    [Edit: in other words, it's the 0.1 m radius of the axle -- not the 1.2 m radius of the entire yo-yo -- that relates torque to force (once the moment of inertia has already been calculated) and angular acceleration to linear acceleration.]
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
