Rotational Motion - Help me out GUYS
The discussion focuses on solving two problems related to rotational motion. For the first problem, the correct approach involves using the formula a = (vf - vi) / t to calculate the train's acceleration as it slows from 90 km/hr to 50 km/hr over 15 seconds, rather than relying solely on a = v^2 / r. In the second problem, participants clarify that to find radial and tangential accelerations, one should use equations involving angular velocity and trigonometric components based on the given angle and net acceleration. Understanding the relationship between linear and angular motion is emphasized as crucial for solving these types of problems. Overall, the discussion provides guidance on applying appropriate formulas and concepts in rotational motion.
dagg3r
hi guys i got a couple of questions can somebody help me out by telling me the steps of where to go about and i will try to get the answer on my own as i need to understand how to do these questions i will post what i know.
1. a train slows down as it turns, from 90 km/hr to 50 km/hr in 15seconds. the radius is 150m, calculate the acclereation the moment it reaches 50km/hr.
first of all i know the formula is a= v^2 / r
what i don't know is that i am given 90k/hr and 50 km/hr, time and a radius, I am thinking maybe i don't use the a=v^2/r formula but perhaps v= u + at ?
2. there is a pictuer of a circle all i am given is radius is 2.50 m, outside the circle is a= 15 m/s^2 and insie the circle is an angle of 30degrees with a line going down. It wants me to calculate radial, tangential accerlearation along with the speed of the particle.
im thinking maybe the a=15 m/s^2 is the overall accleration and maybe use the components of sin30 and cos30 I am lost please shed me some light ppl thanks
You are in the right track. You find the centripetal acceleration as a = v^2/r and tangential acceleration as a = v-u/t. Add them as vectors and you will get the net acceleration.
As far as I get it, you're given the net acceleration a of a particle at the edge of the wheel of radius r, crossed by a radial line forming 30degrees with the vertical. So you are asked to find the radial and tangential accelerations of that particle. But still you would need the speed of the wheel.
For the first question, you are correct in thinking that the formula a=v^2/r may not be the most appropriate in this case. Instead, you can use the formula a=(vf-vi)/t, where vf is the final velocity (50 km/hr), vi is the initial velocity (90 km/hr), and t is the time (15 seconds). This will give you the acceleration of the train as it slows down.
To find the tangential and radial acceleration in the second question, you can use the equations at=ar=ω^2r and at=ωr, where ω is the angular velocity. You can calculate the angular velocity using the formula ω=v/r, where v is the speed of the particle. Then, use trigonometry to find the components of the acceleration in the radial and tangential directions.
I hope this helps shed some light on the problems. Remember to always carefully read the given information and use the appropriate formulas to solve the problems. Keep practicing and you will get the hang of it! Good luck!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
