Rotational Motion with Elastic P. Energy?
The discussion revolves around a physics problem involving a box on a rotating wedge connected to a spring. The goal is to find the equilibrium position of the box while considering forces acting on it due to rotation and spring tension. Key points include the need to account for rotational kinetic energy and the forces from the normal and spring forces acting on the box. The equilibrium condition requires balancing these forces, particularly the centrifugal force resulting from the rotation. Understanding these dynamics is crucial for determining when equilibrium is achievable.
phyzz
Consider a small box of mass m sitting on a wedge with an angle θ and fixed to a spring
with a spring constant k and a length in a non-stretched state L. The wedge
rotates with an angular velocity ω around the vertical axis. Find the equilibrium
position of the box and discuss the conditions when such equilibrium is possible and when it is impossible. The box can move only in the direction along the wedge slope and cannot move in the perpendicular direction (e.g. it is on a rail)
2. The attempt at a solution
First of all I don't know what it's asking exactly so I started with Fmax? I.e. when the mass is going up the plane.
I started with Conservation of Energy:
1/2mv^2 = 1/2kx^2 + mgh (general equation using r = L and h = Lsinθ)
v^2/r = ω (circular motion)
vmax^2/r = kx^2/mr + 2gh/r (I divided everything by r so it fits into the Fmax equation using mrω^2 instead of mv^2/r)
In the end I get Fmax = kx^2 + 2mgLsinθ
Could someone help me out please? I'm really lost :(
The problem with your energy equation is that the system has rotational kinetic energy due to the spinning. For the box to be in equilibrium it will be moving in a circle which means there is a force m\omega^2r on the box parallel to the horizontal pointing away from the slope. This force comes from the normal force from the slope and the spring.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
