haushofer said:
Hi, I have something which bothers me some time and I hope some-one can relieve me from this burden.
If one takes the space-time interval in Cartesian Coordinates, one gets
ds2=dt2-dx2-dy2-dz2.
Ofcourse we could write this in polarcoordinates etcetera. Now, if we want to describe a circular motion, some people claim that this can be done by the special theory of relativity. But, I've learned at a course GR that, if we have a force, the geodesic equation of motion should get a force-term. Carroll for instance states that if we have a charged particle with a Lorentzforce, he writes the tensorial force-term in the geodesic equation ( page 70 of his lecture notes on GR ); instead of 0 the geodesical term equals the Lorentzforce. How should we describe this case in special relativity? I see that the connectionterms become zero in flat space time and stuff, but I don't know how to proceed. Also because I'm not very familiar in describing accelerations in special relativity.
In SR, we must describe the geometry of space-time in a Minkowskian reference frame.
Thus if we have a particle moving in a circle, we typically pick the center of the circle as the origin of our inertial frame and then we just write
x = cos(wt), y=cos(wt)
as Hurkyl mentioned.
Anything more exotic, involving any sort of non-Minkowskian coordinates, involves GR, not SR. SR describes the motion of object in Minkowskian reference frames, just like Newtonian mechanics describes the motion of objects in inertial frames.
The acceleration of an object in SR is described by it's acceleration 4-vector.
To compute the acceleration 4-vector, we start by specifying the curve that the object is following parametrized as a function of proper time, i.e. we have 4 functions
[t,(\tau),x(\tau),y(\tau),z(\tau)]
For your example of a circle, I think the appropriate parametrization would be
t(tau) = t/sqrt(1-(w*r)^2/c^2)
x(tau) = r*cos(w*tau)
y(tau) = r*sin(w*tau)
but I haven't double-checked this
Given this parametrization of the curve, one then computes the acceleration 4-vector as follows:
<br />
[\frac{d^2t}{d\tau^2},\frac{d^2x}{d\tau^2},\frac{d^2y}{d\tau^2},\frac{d^2z}{d\tau^2}]<br />
Like the velocity 4-vector, the accelration 4-vector is a geometric object. It's talked about at some length in MTW's section on the accelerated observer. (MTW = "Gravitation", Misner Thorne Wheeler).
Because it is a geometric object and because we are doing SR, the acceleration 4-vector can be boosted just like any other 4-vector.
Some other useful properties of the acceleration 4 vector are:
In an inertial frame co-moving with the accelerating object, it is equal to
(0,ax,ay,az), where ax,ay,az is the tradiational "3-vector" form of the acceleration
The acceleration 4-vector is always perpendicular to the velocity 4-vector (This is proved in detail MTW, it happens because the velocity 4-vector always has a constant length)
The Geodesic equation that you were talking about earlier actually gives the GR equivalent of SR's acceleration 4-vector.
When we use 4-vectors, we can say that F^i = ma^i, the force 4 vector is the mass (invariant mass!) times the acceleration 4-vector.
In GR, we say that
<br />
F^i = m (\frac{d^2 x^i}{d\tau^2} + \Gamma^i{}_{jk} \frac{dx^j}{d\tau}\frac{dx^k}{d\tau})<br />
m is again the invariant mass.
[add]
You might think of this as replacing the ordinary derivative in the 4-acceleration formulas of SR with the covariant derivative. But I'm not aware of any special name usually given to the vector Fi/m offhand. It's what laypeople usually mean when they talk about "gravity", though, after one converts the 4-vector into a 3-vector. "gravity" can thus result either from coordinate acceleration, or from Christoffel symbols - and it's a quantity associated with a specific path through space-time.
[end add]
The force on an object following a geodesic is zero.
Thus the various components of the geodesic equation serve as GR's equivalent of the SR acceleration 4-vector.
Note that IF an object is following a worldline where all the spatial components of x^i are constant, then
F^i = m \Gamma^i{}_{00} (dt/dtau)^2
0 representing the time component. (All the other first and second derivatives are zero, except for dt/dtau)
