Exploring Energy and Drag in Rubber Band Powered Boats
  • Thread starter tanwan89
  • Tags
    Boat
In summary, the conversation was about a project involving a rubber band powered boat. The person was unsure about which physics theory to incorporate and asked for help. They tested the boat with different numbers of rubber bands and recorded the time it took to reach the end of a bathtub. They also discussed using the same strength rubber bands and calculating drag force and kinetic energy. The boat started sinking when 8 rubber bands were added and flipped over when 10 were added, possibly due to too much power and increased drag. The person also asked about the distance traveled and the reason for the boat flipping over.
tanwan89
I am doing a rubber band powered boat for a project, but I'm not too sure as to what physics theory I can incorporate into it. We made a small wood board boat and powered in using rubber bands and tested to see how long it took to reach the end of the bath tub. Every time we added one more rubber band and saw that when we added the 8th rubber band, the boat started to sink. When we added the 10th rubber band, the boat flipped over.
How do I know the energy in joules?
I would really appreciate your help.
Make sure you're using the same strength rubber bands ie when you use the rubber band to lift a small weight it stretches the same length for each rubber band.
You could try pulling the watercraft with a rubber band to see how much drag force the boat has and use hooks law (assuming the rubber band follows it) to compute a force value. Then from there take measurements of the time and the distance to the end of the pool vs number of rubber bands used.
The drag would be proportional to the speed of the boat.
These are the results:
#rubber bands Time to reach end of tub (s)
1 Did not reach
2 8.5 s
3 4.8 s
4 4.2 s
5 3.5 s
6 3.4 s
7 3 s
8 3.5 s (began sinking)
9 3.6 s
10 3.7 s (flipped over)
I used the same strength of rubber bands. The above data is all I have to come out with a theory and calculations. The bathtub distance is 4.5m. What exactly would I be able to calculate with this data?
I know that the more rubber bands we added, the faster the boat traveled.
I'm sorry I have not taken physics before, thus I am very lost.
what is the distance traveled in meters?
Could you use KE = 1/2 m v^2 to determine the effective kinetic energy as you add each rubber band?
'm' stands for mass of the boat?
yes its the mass of the boat preferably in MKS units.
Oh ok. Thank you very much for your help. I really appreciate it! :)
I have one more question. Why did the boat start to sink when we added the 8th rubber band? And why did it flip over when we added the 10th?
too much power supplied is my guess.
when a boat is pushed thru the water the front rises. It rises higher and higher based on the speed and eventually the speed is too great and it flips. I'm guessing it flipped bcakward right?
try pushing the boat your self and you'll feel the drag from the water pushing back. If you use your finger and push real hard it should flip.
What is a rubberband powered boat?
A rubberband powered boat is a small watercraft that is propelled by the energy released from a stretched rubberband.
How does a rubberband powered boat work?
The rubberband is attached to a paddle or propeller, and when it is released, it contracts and spins the paddle or propeller, propelling the boat forward through the water.
What materials are needed to make a rubberband powered boat?
To make a rubberband powered boat, you will need a lightweight material for the hull (such as balsa wood or foam), a rubberband, a paddle or propeller, and some glue and tools for assembly.
What are the advantages of a rubberband powered boat?
Rubberband powered boats are environmentally friendly, as they do not require any fuel or electricity to operate. They also offer a fun and engaging way to learn about physics and engineering principles.
Are there any safety concerns when using a rubberband powered boat?
As with any water activity, it is important to always supervise children when using a rubberband powered boat. It is also recommended to use the boat in calm or shallow waters to avoid any potential accidents.
  • General Engineering
