Running up some stairs, kiloWatts
  • Thread starter Thread starter Fringan
    Running
The discussion focuses on calculating the power output in kilowatts while running up stairs. The participant calculated the energy used to ascend 2.52 meters and move horizontally 3.5 meters, resulting in an estimated total power output of 0.88 kW. Clarifications were made regarding the calculations, specifically the correct application of time in the power formulas. The conversation also touched on the assumptions made about horizontal motion and the neglect of frictional forces. Overall, the calculations were refined for accuracy while remaining within the basic physics framework taught in the class.
Fringan
Ok, so I'm supposed to run up some stairs and then calculate how much effect (watts) I used.
This is how I did it:
Stairs was 2.52 meters high and 3.5 meters long, my mass is 72 kilos and I ran up the stairs in 2.72 seconds.
Energy for moving up 2.52 meters:
E_{p} = mgh = 72*9.82*2.52 = 1781.7408
P_{1} = \frac{E_{p}}{t} = \frac{(\frac{72*9.82*2.52}{2.72})}{2.72} \approx 0.66 kW
Energy: for moving the 3.5 meters horizontally:
v = \frac{3.5}{2.72}
E_{k} = \frac{mv^2}{2} = \frac{72(\frac{3.5}{2.72})^2}{2.72}
P_{2} = \frac{E_{k}}{t} \approx 0.22 kW
Alltogether: P_{1} + P_{2} = 0.66 + 0.22 = \underline{0.88 kW}
I'm not supposed to think about air friction etc.
Question is ofcourse: Am I anywhere close to answering this in a correct way?
For the first part, why did you divide by 2.72 twice? P=\frac{\Delta{E}}{\Delta{t}}. The second part is tricky. If you ignore non-conservative forces such as friction, the only work you do in the horizontal direction is that which is required for you to accelerate to a certain velocity. Once you reach a given horizontal velocity, because there are no frictional forces (in theory), you do not have to do any more work to continue moving at that velocity. Therefore, you must make some assumption for this part. You can assume that you accelerated at a constant rate in the horizontal direction, and use \Delta{d}=v_{1}\Delta{t}+\frac{1}{2}a(\Delta{t})^2 to find a, F_{net}=ma to find net force, then sub that into W=Fd\cos{\theta}, where theta would be 0. I get about 88W for just the horizontal motion.
Looking at the math a second time I see I wrote in a number of mistakes, sorry - first time using this LaTeX thing :)
this is how the first P was supposed to be (not dividing with 2.72 twice)
P_{1} = \frac{E_{p}}{t} = \frac{72*9.82*2.52}{2.72} \approx 0.66 kW
And the second E was supposed to be like this (dividing with 2, not 2.72):
E_{k} = \frac{mv^2}{2} = \frac{72(\frac{3.5}{2.72})^2}{2}
Also this very basic class I'm taking doesn't deal with cosinus etc yet so i expected the answer to be pretty much basic and simple (like mgh and \frac{mv^2}{2})
A Full Stack Development Program prepares students to create end to end web applications using front end as well as back-end technologies. The purpose is to get experience in creating user interfaces, managing databases, and conducting server-side activities, resulting in a thorough understanding of how web platforms work. This skill is essential since it allows developers to participate at every step of a project, enhancing critical thinking and productivity. registering in Full Stack...
