Russell's Paradox: Understanding the Contradiction of Sets
  • Thread starter Thread starter cesc
    Paradox
Russell's Paradox arises from the set X, defined as the set of all sets that do not contain themselves, leading to a contradiction. The discussion explores the meaning of a set containing itself, with examples illustrating how this concept can manifest in practical scenarios, such as expense lists and programming classes. It emphasizes that adding a type system can help prevent self-containing sets, although some argue that simpler axioms like the axiom of foundation may suffice. The conversation also touches on the Zermelo-Fraenkel (ZF) axioms, which assert that paradoxical sets cannot be constructed, thus avoiding Russell's Paradox. Ultimately, the paradox highlights the complexities of set theory and the importance of foundational axioms in mathematics.
cesc
I understand how the argument goes- let X be the set of all sets which don't contain themselves.
If X contains itself, then X is not in X
If X doesn't contain itself, then X is X
the part i don't understand is, What on Earth does it mean for a set to contain itself?
garbage in, garbage out?
It means that the set is an element of itself. For example, an expense list might be viewed as a set of items (the items listed on it). If the expense list itself is listed as an item on the expense list, then that set contains itself.
The resolution is to add a type system which prevents sets from containing themselves, even indirectly.
well the example seems kind of frivolous.
Also, I'm not sure if its quite right. The word "list" has the dual meaning of a set, and a piece of paper which is an expenseAre there any examples involving mathematical objects?
X \in X.
Sets containing themselves don't cause a problem. And even if you want to exclude them, you can just use the axiom of foundation, rather than trying to do something more elaborate.
Could you give a concrete example where X is an element of X
X = {X}
No problem there.
If you look at the ZF axioms, it's not too hard to see that there is no set that contains itself.
Suppose X is a set, and consider the set {X}. Now (following Wikipedia, anyway), the axiom of regularity says: "Every non-empty set x contains a member y such that x and y are disjoint sets." Well, {X} is a nonempty set, and its only member is X. Thus, {X} and X are disjoint; since X is in {X}, X is not in X.
The axiom of foundation (regularity) doesn't help avoid Russell's paradox. If the paradox can be constructed in a theory X, then it can be constructed in the theory X + foundation (and leads to contradiction, naturally).
Russell's paradox doesn't occur in ZF because such paradoxical sets cannot be constructed in the first place -- the axiom of specification isn't powerful enough.
Here's a more practical example.
class LinkedNode
public LinkedNode next;
public String data;
The class in Java defines a "set" which may contain elements, "objects". Saying object A is an instantiation of class B is basically to say that B = {X | X has the given properties} and A is in B.
Here, LinkedNode contains itself. Even if you take a class definition to be a an ordered n-tuple of its properties rather than a set, you still have
(next, data) = {next, {next, data}} or {{next, data}, data} (definition of ordered n-tuple, I think?)
In the first example, next is in LinkedNode because it's the first element in the list... in the second, because it is in the first set, which is in the outside set.
So, despite it all, you can certainly have things like X = {X} and Z = Z x Y...
