S parameters of Common base configuration
To extract S-parameters for a common base configuration from common emitter S-parameters, one must understand the relationships between the two configurations. Relevant textbooks on BJT basics provide foundational knowledge on this topic. A clarification was made regarding the confusion between S-parameters and H-parameters, emphasizing the need for accurate terminology. Examples and specific conversion methods were requested to aid in understanding. Further resources and detailed explanations can enhance comprehension of this topic.
baby_1
Hello
I want to know it we have common Emitter s parameters how can we extract s parameters of common base configuration?if there is no problem give me some examples in converting
Thank you
baby_1 said:
Hello
Thank you
Can be found in many relevant textbooks covering BJT basics.
Hello Dear Lvw
could you introduce me name of some of them?
Thanks
Sorry, I have mixed-up s-parameters (your question) and h-parameters.
Here's something that might be relevant.
Likes baby_1
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
