A Saddle point Integrals with logarithm and cosine
Leo_rr
I'm trying to use the saddle point method to solve the following integral:
Z = (1/sqrt{2 pi t}) ∫_{1}^{infinity} ds (1/sqrt{2 pi s}) exp{ p [-s ln(s/t) +s] } cos(2 pi L~ p ~ s), as p → infinity
Mod edit to make integral more readable:
$$Z = \frac{1}{\sqrt{2\pi t}} \int_1^{\infty} \frac 1 {\sqrt{2 \pi s}} e^{p(-s \ln(s/t) + s)} \cos(2 \pi L p s)ds$$
$$\lim_{p \to \infty}Z = ? $$
Is this the correct integral?
where L and p are Integers. If we remove the fast oscillatory cosine, the Sadde Point method is straightforward and the solution is:
Z = e^{pt}
Introducing a fast oscillatory function in the integral, one would expect the value of Z to be much smaller, but the direct (or maybe naive) application of the method results in the exact same result, and that's absurd! Have anybody faced a similar problem?
Mathematics news on Phys.org
I think you should write the cosine as the sum of two exponentials which can then be combined with the other exponential and you get two integrals of which each can be evaluated by the saddle point approximation.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
I'm interested to know whether the equation $$1 = 2 - \frac{1}{2 - \frac{1}{2 - \cdots}}$$ is true or not. It can be shown easily that if the continued fraction converges, it cannot converge to anything else than 1. It seems that if the continued fraction converges, the convergence is very slow. The apparent slowness of the convergence makes it difficult to estimate the presence of true convergence numerically. At the moment I don't know whether this converges or not.
