Sakurai 2.17 - More elegant solution help?
  • Thread starter Thread starter Domnu
    Sakurai
Domnu
Problem
Show for the one-dimensional simple harmonic oscillator
\langle 0 | e^{ikx} | 0 \rangle = \exp{[-k^2 \langle 0 | x^2 | 0 \rangle / 2]}
where x is the position operator (here, k is a number, not an operator, with dimensions 1/length).
My Solution
Well, I already know how to do this problem, but my solution isn't as clean. I was searching for a more elegant solution. Here's the outline to my solution:
1. We know that e^{ikx}|p'\rangle = |p' + \hbar k\rangle (pretty simple to prove).
2. We can show that
\langle 0 |e^{ikx}| 0 \rangle = \int dp' \langle 0|p' \rangle \langle p'-\hbar k | 0 \rangle​
by putting everything in the momentum basis.
3. We then just need to find the harmonic oscillator's ground state in the momentum representation, which is just a Fourier transform of the ground state in the position representation.
4. Substitute into the thing got in #2 and compute away, leading to the equality. (and this works, after expanding everything)
As we can see, computing the Fourier transform in step 3 and computing everything in step 4 takes some time, and isn't exactly the "winning" solution.:smile: So would someone help me find or post a more elegant solution?
I don't know if this is more elegant or not, but ...
1) Expand in powers of k.
2) Note that expectation value of odd powers of x is zero, because the ground-state wave function is an even function of x.
3) Prove that
\langle x^{2n}\rangle = (2n{-}1)!\,\langle x^2\rangle^n.
Useful identify for the proof:
\int_{-\infty}^{+\infty}dx\;x^{2n}e^{-cx^2}=\left(-{d\over dc}\right)^{\!n}\int_{-\infty}^{+\infty}dx\;e^{-cx^2}.
4) Resum the series.
Wow... number three seems to be pretty useful! This was actually my initial first approach... I found a really neat analog to the Catalan numbers, but wasn't able to complete it. I'll go and try out this approach. Thanks a lot for the help :smile:
In quantum field theory #3 is known as Wick's theorem.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
