Sakurai page 181: Time evolution of ensembles
omoplata
From "Modern Quantum Mechanics, revised edition" by J. J. Sakurai, page 181.
Equation (3.4.27), at some time t_0, the density operator is given by<br /> \rho(t_0) = \sum_i w_i \mid \alpha^{(i)} \rangle \langle \alpha^{(i)} \mid<br />Equation (3.4.28), at a later time, the state ket changes from \mid \alpha^{(i)} \rangle to \mid \alpha^{(i)}, t_0 ; t \rangle.
Equation (3.4.29), From the fact that \mid \alpha^{(i)}, t_0 ; t \rangle satisfies the Schrodinger equation we obtain<br /> i \hbar \frac{\partial \rho}{\partial t} = \sum_i w_i \left( H \mid \alpha^{(i)}, t_0 ; t \rangle \langle \alpha^{(i)}, t_0 ; t \mid - \mid \alpha^{(i)}, t_0 ; t \rangle \langle \alpha^{(i)}, t_0 ; t \mid H \right) = - \left[\rho, H\right]<br />How does he get to (3.4.29) by applying to Schrodinger equation?
From (2.1.27), the Schrodinger equation is given to be<br /> i \hbar \frac{\partial}{\partial t} \mid \alpha, t_0 ; t \rangle = H \mid \alpha, t_0 ; t \rangle<br />I can't figure out how to apply it to get (3.4.29).
Both the bra and the ket are evolving in time. Formally, the time derivative of the ket-bra outer product obeys the normal product rule for derivatives:
##\frac{d}{dt}(|\alpha \rangle \langle \beta |) = (\frac{d}{dt} | \alpha \rangle) \langle \beta | + | \alpha \rangle (\frac{d}{dt} \langle \beta | )##.
(Here ##|\alpha \rangle## is any ket and ##\langle \beta |## is any bra). If you apply this to your density operator you should get the desired result. Note that to evaluate the time derivative of a bra you will have to use the Hermitian conjugate of the Schrodinger equation.
If you want to make it totally transparent why the normal derivative product rule applies in this case, you can consider the infinitesmial time evolution of a ket:
##|\alpha(t+dt) \rangle = |\alpha(t)\rangle + dt \frac{d}{dt}|\alpha(t)\rangle##
If you write down the analagous formula for a bra, and then use the two formula to evaluate ##| \alpha(t+dt) \rangle \langle \beta(t+dt) |## then you should be able to derive the claimed product rule for derivatives (at the physicist level of rigor, anyway).
It is simply the application of the Schrödinger equation plus hermitean conjugation
\partial_t\,(|a\rangle\langle a|) = (\partial_t \,|a\rangle)\,\langle a| + |a\rangle \, (\partial_t\,\langle a|) = (-iH|a\rangle)\langle a| + |a\rangle(\langle a|(-iH)^\dagger) = -i(H|a\rangle\langle a| - |a \rangle\langle a|H) = -i [H,\rho]
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
