Salty water showing a voltage?
  • Thread starter Thread starter SMD1990
    Voltage Water
A user conducted an experiment by measuring the voltage and current in a saltwater solution using a digital multimeter. They observed fluctuating voltage readings, reaching up to 300 mV, with a current less than 0.1 mA. The voltage was unstable, showing significant variation over time but eventually stabilizing around 30 mV after hours. The user noted that their analog multimeter, which has a minimum range of 10 volts, could not detect the small millivolt readings. They speculated that the phenomenon might be related to the dissolution of table salt in water. The discussion also included a mention of using wet coffee filters as electrodes and referenced a bioengineering professor's experiments with charge separation in water, suggesting that the probes might be reacting with the solution.
SMD1990
Hello. Today, I have observed something which I do not understand. I have a glass of water with some table salt in it. I stuck the probes of my digital multimeter into the water. Strangely, I am getting a reading.
If there is any current, it is less than a tenth of a mA. Still, the voltage has been as much as 300 mV. Though, unsteady.
It went up and down, perhaps as low as half the peak value. Then, it would recover. Sometimes, it would hang around one value with little change. Then suddenly, it would begin to quickly change, before slowing again.
Even after hours, I still see about 30 mV. Though, it is a lot more steady now.
Just a moment ago, I repeated what I did earlier in the day. Similar results.
My analog multimeter does not show any voltage. Then again, the smallest of its ranges is 10 volts. Such small millivolt readings are difficult to make.
Anyway, does this have to do with the dissolution of the table salt? That is the only answer I can come up with...
I had never heard of this before...
Chemistry news on Phys.org
What are your electrodes made of?
Wet coffee filters.
Then later, just whatever my multimeter's probes were made of.
Here is a video of a bioengineering professor who is making some interesting experiments with water. With water, hydrophylic surfaces and sunlight he is achieving charge separation, making batteries and doing other neat stuff.
Respectfully submitted,
Steve
SMD1990 said:
Wet coffee filters.
My bet would be that you observe your probes reacting with the solution.
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
