Calculating Orbital Height for a Satellite Orbiting the Earth
  • Thread starter Thread starter shad0w0f3vil
    Earth Satellite
To determine the orbital height of a satellite that remains stationary relative to the Earth, the satellite must have a period equal to the Earth's rotation period of 24 hours. The discussion highlights the importance of using Kepler's Third Law, specifically the equation T^2 = (4πr^3)/(GM), where T is the orbital period, r is the distance from the Earth's center, G is the gravitational constant, and M is the Earth's mass. Initial calculations led to confusion, with incorrect values being suggested, but the correct approach involves solving for r using the established formula. The final value suggested in the discussion was 6,380,000 km, which was later challenged as incorrect. The conversation emphasizes the need for accurate application of the formula to find the correct orbital height.
shad0w0f3vil
Hi there,
I received this question with regards to planetary (or in this case satellite) motion:
Determine at what height above the Earth an arteficial satellite must orbit if it is to remain in the same place relative to the Earth (Hint: Model the situation using Kepler's Laws of Motion).
I believe that both the second and third laws are not applicable for this question, meaing the first law should be used. I am just unsure of how to 'start' it off.
Any help with this would be greatly appreciated.
The third law is the only one that matters. What is it? Why can't you use it?
I thought I didnt have enough information. For example I do not know the period
If it remains in the same place relative to the earth, it must go around the Earth in the same time it takes the Earth to rotate. I.e. it's period must be 24 hours.
ok so how do i work out my distance from the Earth then? or do i work with respect to the sun?
Just that when I try it i end up with the average distance being equal to 0km, which obviously is not correct
hold that thought, I managed to get a different answer from 0. I got, 6,380,000km.
any ideas on this value?
Yes. They are both way wrong. Could you show us the equation you are using and the numbers you are plugging into it?
Hint: T^2=\frac{4\pi r^3}{GM}
M is the mass of earth...
