Why does saturation of a ferromagnetic result in non-sinusoidal current?
When a ferromagnetic material saturates, the current becomes non-sinusoidal due to the non-linear relationship between the magnetic field and the current. As the magnetic domains align in saturation, increases in current do not result in proportional changes in the magnetic field. This leads to a reduced opposing voltage, allowing the current to rise more than expected under linear conditions. The phenomenon is particularly evident around the saturation peaks, where the core's behavior deviates from linearity. Understanding this interaction between the magnetic and electric fields is crucial for analyzing transformer magnetizing currents.
tonyjk
Hello... I have a question: Physically why when a ferromagnetic is saturated the current is non-sinusoidal ( I'm taking the example of the magnetising current of a transformer). I know graphically and mathemeticalty why( from the hysteresis loop) but In reality what happens(I'm talking about magnetic field or/and electric field) . I know the magnetic domain of the iron core will be aligned etc... but why there's a non-sinusoidal current... Thanks
The principle of an inductor is that it surrounds its coils with a magnetic field (that field being produced by the current in the coils). So any change in current in the coils induces a voltage in the coils and this voltage tends to oppose the change in current that produces it. Ideally, there exists a linear relationship between the current and the field.
Around those peaks where the core starts to saturate (i.e., show non-linear behaviour), a further increase in current fails to produce the full expected change in the magnetic field, this in turn induces less opposing voltage to oppose that current, with a consequence that the current is able to increase more than for expected linear behaviour.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
