Tony Stark
- 51
- 2
What is the scalar product of orthonormal basis? is it equal to 1
why is a.b=ηαβaαbβ having dissimilar value
What do you mean by INNER PRODUCTOrodruin said:There is no such thing as a scalar product of a basis. The only possible interpretation of your question is what the scalar product between two vectors in an orthonormal basis is. The answer is that if you take two different vectors of the basis, it is zero (this is the "normal" part of orthonormal) while if you take the inner product of one of the vectors in the basis with itself you get ±1 depending on whether you chose a timelike or spacelike basis vector.
Orodruin said:The answer is that if you take two different vectors of the basis, it is zero (this is the "normal" part of orthonormal)
PeterDonis said:Actually, it's the "ortho" part, correct? The "normal" part is the ##\pm 1## you get when you take the inner product of a basis vector with itself.
The scalar product of orthonormal basis is a mathematical concept that involves multiplying two vectors to obtain a scalar value. It is also known as the dot product and is denoted by a dot (·) between the two vectors.
The scalar product of orthonormal basis is calculated by multiplying the corresponding components of the two vectors and then adding the products together. For example, if the two vectors are a = (a1, a2, a3) and b = (b1, b2, b3), then their scalar product would be a1b1 + a2b2 + a3b3.
The scalar product of orthonormal basis is important in mathematics because it allows us to determine the angle between two vectors, find the projection of one vector onto another, and calculate the magnitude of a vector.
When the scalar product of orthonormal basis is equal to 1, it means that the two vectors are perpendicular to each other. This is because the cosine of 90 degrees (the angle between two perpendicular vectors) is equal to 0, and the scalar product is equal to the product of the magnitudes of the two vectors multiplied by the cosine of the angle between them.
The scalar product of orthonormal basis is closely related to linear independence. If the scalar product of two vectors is equal to 0, it means that the vectors are orthogonal (perpendicular). This indicates that the two vectors are linearly independent, as they are not parallel to each other and cannot be expressed as a multiple of one another.
