Scholarpedia article on Bell's Theorem
565 replies · 72K views
DrChinese said:
The funny thing to me is that you mention in the article how EPR makes an argument for "pre-existing values" if QM is correct and locality holds... which to me IS realism. Then you deny that realism is relevant to Bell, when it is precisely those "pre-existing values" which Bell shows to be impossible.
1) EPRB: "locality"+"QM is correct"--->"pre-existing values"
2) Bell's Inequality: "pre-existing values"+"QM is correct"--->Contradiction.
3) Join 1) and 2) and you get: "locality"+"QM is correct"--->Contradiction.
All this is explained ( (1) is not explained with total mathematical rigour at that stage, but (2) is ) before his "CHSH-Bell Inequality: Bell's Theorem without perfect correlation".
In this CHSH Theorem, what he proves is that "some very general mathematical setup (that accounts for almost any imaginable way a Theory could produce mathematical predictions, not only for those with pre-existing values)" + "factorizability condition"+"QM is correct"--->Contradiction.
Then he uses this CHSH-Theorem to prove mathematically (1).
At the end, to prove (1) with mathematical rigour he is using CHSH-Theorem, so in reality he is also using his "very general mathematical setup" to state and prove with mathematical rigour EPR argument.
But all you need to look at is CHSH-Theorem (the rest is only to make it easier for those who can not understand this CHSH-Theorem and proof). That very important mathematical Theorem states:
"a very general mathematical setup (that accounts for almost any imaginable way a Theory could produce mathematical predictions, not only for those with pre-existing values)"+"factorizability condition"+"QM is correct"--->Contradiction.
Let me summarize my own viewpoint, and let's see how much agreement I can get. Let's suppose that QM is correct about all its experimental predictions. Then whenever you turn the polarizers to the same angle, you will get perfect correlation. From this you can reach three possible conclusions:
1. Even when you don't turn the polarizers to the same angle, it is still true that if you HAD turned the polarizers to the same angle, you WOULD have gotten perfect correlation.
2. When you don't turn the polarizes to the same angle, it makes no sense to ask what would have happened if you had turned them to the same angle.
3. When you don't turn the polarizers to the same angle, then it may be the case that you wouldn't have gotten perfect correlation if you had turned them to the same angle.
If we assume the principle of locality (i.e. excluding backward causation), then the only way option 3 would be possible is if the photons "knew" in advance what angle the polarizers would be turned to, or equivalently whatever is controlling the experiment decisions about the polarizer settings "knew" in advance whether the two photons would do the same thing or not. That would be superdeterminism, and we exclude it by the no-conspiracy condition.
So now we have two options left. Quantum mechanics takes option 2. But if you believe in counterfactual definiteness, you are forced into option 1. And then if you accept option 1 and the principle of locality (again, excluding backward causation), you are forced to conclude that the decision of each photon to go through or not go through must be determined by local hidden variables that are shared by the two photons. Is this a fair summary of the EPR argument?
DrChinese said:
There is a problem distinguishing Bell's Locality condition from the question of what "Locality" means in the sense that causal/temporal direction was assumed to occur in one direction only. At this point, that cannot be assumed.
Except that, really, it already is being assumed, in the very act of using the words "cause" and "effect". A cause and an effect are two events that are linked by some law-governed process. Which one is the cause and which one is the effect, would be very hard to answer without just saying: the cause is the one that happens first, the effect is the one that happens later.
But, there's probably no point arguing about this. If we can agree that, on *Bell's* definition of "locality" (in which it is assumed that causation only goes forward in time), everything in the scholarpedia article is true, I will be satisfied. =)
DrChinese said:
I would agree that when discussing Bell's Theorem, you can do it "mostly" independently of the later no-gos. On the other hand, you should at least mention those no-gos that Bell has spawned, including those which attack realism (such as GHZ).
I guess you haven't read sections 8 and 9 of the paper yet.
Of course, to do that you would need to accept realism as part of Bell. The funny thing to me is that you mention in the article how EPR makes an argument for "pre-existing values" if QM is correct and locality holds... which to me IS realism. Then you deny that realism is relevant to Bell, when it is precisely those "pre-existing values" which Bell shows to be impossible.
This is what I've explained several times already. For "Bell's theorem" (as we use that term, i.e., meaning the argument comprising both the EPR argument and "Bell's inequality theorem") the idea of "pre-existing values" or "realism" or whatever you want to call it, functions only as a middle term:
EPR: locality --> X
BIT: X --> inequality
Hence Bell's theorem: locality --> inequality.
If the two sub arguments are good arguments, then the conclusion follows, no matter what X is, whether you like X or not, whether you think X is true or not, etc.
EPR-B would be summarized more like (using lingo of EPR):
[Ability to Predict with Certainty]
+ [Without first disturbing]
-> Element of Reality
To quote: "If, without in any way disturbing a system, we can predict with certainty (i.e., with probability equal to unity) the value of a physical quantity, then there exists an element of physical reality corresponding lo this physical quantity."
This is for ONE particle, folks. Has nothing to do with two. The second particle is merely a tool to obtain the prediction, but anyway you do that would be acceptable. The locality condition is implicit in the idea that you are not disturbing the particle you are making the prediction on, especially by way of transmitting the nature of how you were able to make the prediction in the first place. Note that we are *not* assuming QM is correct. Just that we would have a setup in which we could make a suitable prediction. That might agree with the QM prediction, sure, but that does not mean QM is correct in other particulars. The discussion about the details of QM relates to the fact that QM does not allow for distinct values for non-commuting operators.
[Elements of Reality]
+ [Reasonable definition of reality assumes their simultaneous existence]
= Realism (this is a definition, nothing to argue about here)
To quote: "In accordance with our criterion of reality, in the first case we must consider the quantity P as being an element of reality, in the second case the quantity Q is an element of reality."
Realism -> More Completeness than QM/HUP allows
So there were 2 assumptions in route to the EPR-B conclusion: i) locality; ii) simultaneous elements of reality independent of observation. If you leave out ii) you end with a definition of reality which they considered unreasonable. So they explicitly assume ii), and I will re-quote this for the Nth time:
"One could object to this conclusion on the grounds that our criterion of reality is not sufficiently restrictive. Indeed, one would not arrive at our conclusion if one insisted that two or more physical quantities can be regarded as simultaneous elements of reality only when they can be simultaneously measured or predicted. ... No reasonable definition of reality could be expected to permit this."
They just said that if the simultaneity requirement is dropped, their argument is squat. Bell didn't much bother to mention it, he thought it was so obvious. But guess what, it is actually important. If there is not a predetermined result from the hidden variables at angle settings which are counterfactual, you don't get any contradictions.
(Just ask billschnieder about this point. :smile: )
Yes, that's right. I almost always find that, once the "two part argument" character of Bell's overall argument is explained clearly, people get it right away. And that is nice, because both parts of the two part argument (namely, the EPR argument from locality to a certain kind of local HV's, and then the derivation of Bell's inequality from the local HV's) are pretty straightforward and can be explained clearly and convincingly without a lot of math. Dr C seems to have a block about it though... maybe for him it would be easier to get the point by looking at "Bell's theorem without perfect correlations"? It has the disadvantage of being a bit heavier mathematically, but does also have the crucial advantage that you never once have to even *mention* the "local realistic deterministic non-contextual hidden variable simultaneously definite values" that seem to be the source of the block.
As a way to introduce Bell's Theorem (BT) to beginners (and more), why not apply Bell to a classical local-realistic experiment?
PS: A challenge to do this (in an Einstein-local setting) already exists at https://www.physicsforums.com/showthread.php?p=3833480#post3833480. For some reason, it so far appears to be a stumbling block for those familiar with BT.
PPS: Travis, in the spirit of your OP, I am preparing a more detailed response to your article, which I very much appreciate. And for which I thank you! However, I expect that my comments will be critical (and hopefully helpful).
Some minor points include: the need for much better editing; to wit, the removal of repetition and the correction of typos; the re-location of much material to appendices; etc. The bias of the authors should be made clear to the reader; bias (imho) being a crucial consideration when it comes to proposed review articles on subjects which are still controversial; the bias in the article tending to the Bohmian (given the assumptions)?
Could you therefore please advise the general tenor of each author's physical beliefs and conceptualisations; e.g., Bohmian, MWI, CI, etc?
At the moment my primary focus is on unwarranted assumptions in your article: assumptions which I test (and find wanting) against a clearly Einstein-local and realistic (because it is wholly classical physics) experiment. That's where the above (even-simpler) experiment comes in.
And that is why I would welcome your thoughts about it. Especially should it be the case that, from your response, I might see that any further critique from me would be superfluous.
With thanks again,
Gordon
Ah, good, I did miss that.
That's a nice, clear way to frame some issues. I agree completely with what you write in the first paragraph after the 1/2/3; 3 is out if you accept "no conspiracies". I don't agree, though, about your statement that "QM takes option 2" or even really that option 2 makes any sense as an option. QM, like any theory, tells you what will happen if you make certain measurements. It's just that it involves an element of (alleged) irreducible randomness: the first measurement collapses the 2-particle-wave-function (in an unpredictable, irreducibly random way), and subsequent predictions for what you will see if you make some measurement on the other particle are obviously affected. So the point is that QM is giving a *non-local* explanation for the statistics -- not that it's "denying counter-factual definiteness".
I really don't even know what this "counterfactual definiteness" stuff is supposed to mean. It seems to me inherently metaphysical. But we never need to get here into a discussion of what does or doesn't "really exist" in some counter-factual scenario. We just have to remember that we are talking about *theories* -- and a theory, by definition, is something that tells you what will happen *if you do such-and-such*. *All* of the predictions of a theory are in that sense hypothetical / counterfactual. Put it this way: the theory doesn't know and certainly doesn't care about what experiment you do in fact actually perform. It just tells you what will happen if you do such-and-such.
So back to your #2 above, of course it makes sense to ask what would have happened if you had turned the polarizers some other way. It makes just as much sense (after the fact, after you actually turned them one way) as it did before you did any experiment at all. How could the theory possibly care whether you've already done the experiment or not, and if so, which one you did? It doesn't care. It just tells you what happens in a given situation. QM works this way, and so does every other theory. So there really is no such thing as option #2.
ttn said:
Quoting Bell: "It is notable that in this argument nothing is said about the locality, or even localizability, of the variable λ."
I guess I missed the argument. How does assuming λ comes from Venus result in denying non-locality??
If λ can be anything, then it can also be a non-local hidden variable. I'm trying to get you to explain how your derivation will be different if λ were non-local hidden variables? It appears your answer is that it won't be different.
The whole idea here is that (in general) there is a whole spectrum of possible values of λ, with some distribution ρ, that are produced when the experimenter "does the same thing at the particle source". There is no control over, and no knowledge of, the specific value of λ for a given particle pair.
Experimenters calculate their correlations using ONLY particles actually measured. Aren't you therefore assuming that for a given particle pair, a particluar value of λ is in play? Such that in a given run of the experiment, you could in principle think of making a list of all of the actually measured values of λ and their relative frequencies (if you knew them), to obtain a distribution of ρ(λ) that is applicable to the calculated correlation for the given run of the experiment? The actually measured distribution of λ for all 4 terms of the LHS must be identical according to your proof.
However as you say that the λs are hidden and the experimenters know nothing about it, you must therefore be making an additional assumption that the distributions are the same for all 4 terms calculated from 4 runs of the experiment, or you could be assuming that all 4 measured distributions are identical to the the distribution of λ leaving the source? Clearly you can not make such assumptions without justification and the justification can not simply be some vague impricise statement about scientific inquiry.
Just to make sure, by the "lists" you mean the functions (e.g.) [itex]E_a(A_1|\lambda)[/itex]?
I'm referring to the list of outcomes from the experiments. In order to calculate E(a,b) from an experiment, you have a list of pairs of numbers with values ±1, as long as the number of particle pairs you actual measured and you calculate the mean of the paired product. For the 4 runs of the experiment used to obtained the 4 terms of the CHSH LHS, you therefore have 8 lists of numbers, or 4-pairs. Therfore Ea, Eb, Ea', Ec each correspond to a single list of numbers.
Huh? Nothing at all implies that. The lists here are lists of outcome pairs, (A1, A2). The experimenters will take the list for a given "run" (i.e., for a given setting pair) and compute the average value of the product A1*A2. That's how the experimenters compute the correlation functions that the inequality constrains. You are somehow confusing what the experimentalists do, with what is going on in the derivation of the inequality.
I'm trying to make you see that what experimenters do is not compatible with the conditions implied in the derivation of the inequalities -- the factorization within the integral, without which the inequality can not be obtained. I have already explained and you agreed that unless the *distribution* of λ is the same for the 4 CHSH LHS terms, the inequality is not derivable.
I don't even understand what you're saying. There is certainly no sense in which the experimenters' lists (of A1, A2 values) will look like, or even be comparable to, the "lists" I thought you had in mind above (namely, the one-sided expectation functions).
For the sake of illustration, assume we had a discrete set of lambdas, say (λ1, λ2, λ3, ... λn) for the theoretical case (forget about experiments for a moment). If we obtained E(a,b) by integrating over a series of λ values, say (λ1, λ2, λ4), the same must apply to E(a,c) and E(b,c) and all the other terms in the CHSH. In other words, you can not prove the inequality if you use E(a,b) calculated over (λ1, λ2, λ4), with E(a,c) calculated over (λ6, λ3, λ2) and E(b,c) calculated over (λ5, λ9, λ8), because in that case ρ(λ) will not be the same across the terms and the proof will not follow. Each one sided function, when considered in the context of the integral (or sum), obviously produces a codomain which corresponds to a list of values, ±1. For the eight lists from the left side of the CHSH, we should be able to sort all list in the order of the lambda indices and if we do this, we must find duplicates and be able to reduce the 8 lists to only 4 lists. Placing these 4 lists sideways therefore, the values for each row would have originated from the exact same λi value. Agreed?
You should then get something like this:
a b a' c
+ - - + λ1
- + - + λ2
- - + - λ3
... etc
+ - + - λn
where the last column corresponds to the actual value of lambda which resulted in the outcomes.
You can understand the list by saying the first row corresponds to A(a,λ1) = +1, A(b,λ1) = -1, A(a',λ1) = -1 and A(c, λ1) = +1
Note that the above is just another way of describing your factorization which you did within the proof. I'm just doing it this way because it makes it easier to see your error.
Now if we take the above theoretical case, and randomly pick a set of pairs from the a &b columns to calculate E1(a,b), randomly pick another set of pairs from the a and c columns to calculate E2(a,c), and the same for E3(a',b) and E4(a',c), don't you agree that this new case in which each term is obtained from a different "run" is more similar to the way the experiments are actually performed? Now starting with these terms, in order to prove the inequality, you have to make an additional assumption that the 8 lists of numbers used to calculate the inequality MUST be sortable and reduceable to 4 as described above. Simply because the inequality does not follow otherwise. Therefore you can not conclude reasonably that violation of an inequality means non-locality unless you have also ruled out the possibility that the terms from the experiment are not compatible with the mathematical requirements for deriving the inequality.
The question doesn't arise. You are just calculating 4 different things -- the predictions of QM for a certain correlation in a certain experiment -- and then adding them together in a certain way.
Very interesting! Note however that as I've explained above and you've mostly agreed, the terms in the LHS of the CHSH are not 4 different things. They are tightly linked to each other through the sharing of one-sided terms. The terms must not be assumed to be independent. They are linked to each other in a cylclic manner. I'm trying to get you to explain why you think using 4 different things
in an inequality which expects 4 tightly coupled things is mathematically correct. Why do you think this error is not the source of the violation.
If I tell you that 2 + 2 = 4. Anybody can violate it by saying 2inches + 2cm ≠ 4inches. So you need justification before you can plug terms willy-nilly into the LHS of the inequality.
I dont' know what you mean by "series of λs". What the assumption boils down to is: the distribution of λs (i.e., the fraction of the time that each possible value of λ is realized) is the same for the billion runs where the particles are measured along (a,b), the billion runs where the particles are measured along (a,c), etc. That is, basically, it is assumed that the settings of the instruments do not influence or even correlate with state of the particle pairs emitted by the source.
I take it you assume measuring a billion times does something special to the result? You said earler that the experimenters do not know anything about the nature or number of distinct λ values. So what makes you think "a billion" is enough? Let us then assume that there were 2 billion distinct values of λ. Will you still think a billion was enough?
What you're saying here doesn't make sense. You're confusing the A's that the experimentalists measure, with the λs that only theorists care about.
Theoretically, you can derive an inequality using terms which can not all be simultaneoulsy measured. However it is naive for experimentalists to think they can just measure any terms and plug them into the inequalities.
Yes, it won't be different. Indeed, if you asked me to characterize what λ is, in non-mathematical terms, I'd just admit openly that it's a "not-necessarily-local hidden variable". (Of course, the terminology "hidden variable" isn't ideal, since that connotes something specifically *supplementary* to the ordinary QM wf, which needn't at all be the case. Maybe "not-necessarily-local outcome-influencing variable".)
Yes, each pair should have some particular λ.
Yes, I think that's right. Of course, you can't/don't actually measure the values of λ. But apparently you meant this as a hypothetical, as in "if you could somehow magically measure them, then you could write down what the value was for each particle pair and look later at their statistical distributions in the different runs".
Yes, I've admitted this openly. We stress it in the article! Yes, yes yes. We *assume* that the distributions are the same for all 4 runs, i.e., for all 4 possible values of the setting parameters. That is, we assume that the distribution of λs is independent of the settings. We call this the "no conspiracy" assumption. Yes, this assumption is needed to derive the inequality. Yes, yes, yes.
I don't understand that. There is no consideration of the λs changing in time. If they change in time (between when they leave the source and "later" when they "do their thing", influence the outcomes somehow) then we need only ever talk about the "later" values and their distribution).
Not everything can be deduced mathematically. If you find the assumption unreasonable, that's cool. Just say you accept the mathematical proof, but find the "no conspiracies" assumption unreasonable. Don't keep saying there's an "error" in the proof!
Sorry, I don't understand it. We are here deliberately trying to avoid the assumption that λ plus the local setting *determine* the outcome. That is, we are here deliberately trying to allow that there is some "residual indeterminism" at the measurement event. So I don't know where you got these functions A.
The factorization here is in terms of the E's. The idea is that λ and the local setting should determine the probabilities for the possible outcomes, hence the expected value; but they need not uniquely determine the outcome; we don't assume determinism.
I don't know how to say it any more plainly. Yes, the conclusion of nonlocality only follows if you make the "no conspiracies" assumption.
Just out of curiosity, would you say the same thing in the coin flip / drug trial analogy I described before? That is, does it violate your sense of scientific propriety to "just assume, without proof" that the coin flip outcomes are uncorrelated with the precise health status of the patients?
I agree that, in principle, it might not be. But we know -- from experience/experiment -- that the statistics *converge* as you do more and more trials. That is, it takes a certain number of trials to get some accuracy, but then as you keep going things "settle in" to some values and don't change as you do more and more trials. Thus, the question of how many trials is enough is an empirical one: do enough trials such that doing more doesn't change the answer. Any experimentalist will tell you that in the case at hand the actual experiments already involve way more than enough trials.
Of course, a certain kind of mathematical rationalist will remain unsatisfied by this: "can you *prove* that things won't suddenly start changing if I take just one more billion data points?" No, I can't prove it. But you run the risk here of committing to a level of skepticism that would have you rejecting every single empirical scientific claim ever made. And that, in my book, cannot be rational.
billschnieder said:
a b a' c
+ - - + λ1
- + - + λ2
- - + - λ3
... etc
+ - + - λn
where the last column corresponds to the actual value of lambda which resulted in the outcomes. You can understand the list by saying the first row corresponds to A(a,λ1) = +1, A(b,λ1) = -1, A(a',λ1) = -1 and A(c, λ1) = +1
It is baffling to me what part of the above you do not understand. Those functions are from Bell's equation (1). In fact A1 and A2 in your article are generated by functions of this type are they not? In anycase you did not say whether you agree or disagree with the requirement to be able to reduce the 8 lists of numbers to 4. Was that part not clear also?
I don't recall using the word determinism. All I stated was the obvious fact, acknowledged by Bell in is first equation, that a given outcome for one particular particle is a function of the instrument setting and the specific lambda which is in play during the measurement of that one particle. ie A(a, λ) = ±1. In any case, I did not say each particular value of λ must occur only once in the list or that, every occurrence of λ must be the same. All I'm saying, and you appear to agree, is that the way in which the inequality is derived demands that the 8 lists be reduceable to 4.
But it is not sufficient to just "say" it, you have to demonstrate what exactly you mean by "no conspiracy" and hopefully this exercise is bringing out the fact that your "no-conspiracy" assumption is simply the assumption that the probability distribution of the λs actually realized in each run of the experiment are exactly identical to each other. This is an unreasonable assumption which can and is in fact violated in many cases where no conspiracy is in play.
This is a contrived analogy with little relevance to what we are discussing. I can randomly pick people from the physics forum members by flipping a coin and ask them if they like physics and conclude from the results that >90% of people like physics; and then when questioned, I can argue that the coin flip outcomes are uncorrelated with the disposition of the people towards physics. So arguments like this do not fly such discussions.
Let me give an analogy which is more relevant to the issue here (borrowed from rlduncan):
Three fair coins are tossed simultaneously by three individuals. For simplicity, let's them be a, b, and c and each coin is tossed eight times. It follows that the outcomes must obey the following inequality
nab(HH) + nbc(HH) ≥ nac(HH)
To see this, consider the following outcomes for the three coins
a =HTTTHTHH
b=TTHHTHHH,
c=HTHTTTHH,
2+3 ≥ 3 , the inequality is satisfied.
However, if in an experiment you decide to perform three different runs of the experiment such that you obtain
a1=HTTHTHHH
b1=THHTTHTT,
b2=HTHHTHHT
c1=TTTTHHTH,
a2=THHTHTTH
c2=HHHTHTTT,
You now have 1+1 ≥ 3 which violates the inequality. Why is that? The reason is simply because the three terms in the inequality are not independent. They are calculated from only 3 lists of outcomes so that there is a cyclic dependency. However in the latter experiment, we have 6 distinct lists not reduceable to 3!
The issue is not the accuracy of an individual value but the relationship between one value and the others. In isolation, you can predict each value separately. But when considering them jointly in an inequality, which was derived the way you did, you can not do that because once one term is determined, the domain of applicability of the others are automatically restricted and their values are no-longer the same as what you predicted for the general case. You do not solve this problem by measuring different series of particles an infinite number of times. Like in the above example, with fair coins, it doesn't matter how many times you throw the coins you will still violate the inequality easily.
You misunderstand. It is up to you to complete your proof before you make extra-ordinary claims that locality is refuted. As you now admit, no experimenter can ever be sure that the same distribution of λ applies to all the terms they calculated. If that is the basis on which you reject locality, then it is indeed a weak basis.
ttn said:
... Anyway, I just thought it might be helpful to advertise the existence of a really systematic, careful review article on Bell's Theorem that Goldstein, Tausk, Zanghi, and I finished last year (after working on it for more than a year). It's free online here
http://www.scholarpedia.org/article/Bell%27s_theorem
and addresses very explicitly and clearly a number of the issues being debated on the other several current Bell's Theorem threads. It is, in my hardly unbiased opinion, far and away the best and most complete existing resource for really understanding Bell's Theorem, so anybody with a remotely serious interest in the topic should study the article. I'd be happy to try to answer any questions anybody has, but post them here and base them somehow on the scholarpedia article since I won't have time to follow (let alone get entangled in) all the parallel threads.
Travis
Travis, just in case you missed it, I've added a PPS to my post at the top of this page:
Gordon Watson said:
Just click the arrow!
Its drift is thus: In the spirit of your OP, I am preparing a more detailed response to your article, which I very much appreciate. And for which I thank you! However, I expect that my comments will be critical (and hopefully helpful).
At the moment my primary focus is on unwarranted assumptions in your article: assumptions which I test (and find wanting) against a clearly Einstein-local and realistic experiment (because it is based wholly on classical physics) .
There's an even simpler experiment at: A challenge to discuss Bell's theorem (in an Einstein-local setting) at https://www.physicsforums.com/showthread.php?p=3833480#post3833480. For some reason, it so far appears to be a stumbling block for those familiar with BT.
How about you?
I would welcome your thoughts about it here: It is relevant to your article. And more especially: It could be the case that, from your response, I might see that any further critique from me would be superfluous or unwarranted (being wrong).
With thanks again,
GW
I thought I should also ask what kind of conspiracy you think is taking place in the coin-flip example which violates the inequality.
And just to be clear, I do not believe there is an error in the proof. The are two errors:
1 - Thinking that the terms from QM could be meaningfully plugged into the LHS of the CHSH.
2 - Thinking that the terms from Experiments could be meaningfully plugged into the LHS of the CHSH.
The terms from experiment and QM are not circularly linked in the same way the inequality was derived. So this is an extra assumption being made in order to use those terms. In order to proclaim that violation of the inequality disproves locality, You have to first prove that this assumption is valid for the QM terms and the experimental data. This has not been done in this article or any other "Bells theorem implies non-locality article".
This is not extreme skepticism, it is simply a matter of sound reasoning. Extra-ordinary claims require extra-ordinary proof.
billschnieder said:
The are two errors:
At least this part IS extreme skepticism. I thought your (fringe) point of view was that any local hidden variable theory WOULD satisfy a Bell inequality, and thus would contradict QM in principle, but that this inequality would be absolutely untestable experimentally because you can't measure three polarization attributes of one entangled pair. (I'm not agreeing with your point, just saying what I thought your point was.) But now are you saying that in addition to all that, you're even skeptical about whether this untestable Bell inequality contradicts QM at all, even theoretically?
I have carefully explained to you previously why experiments violated the inequalities. You did not say if you disagreed with anything in my explanation. You never asked me for the reason why QM violates the inequality, and it has come up in this thread that the reasons are not very different. So what exactly is suprising to you?
I will ask you the same questions I asked ttn:
- Are the 4 terms in the CHSH independent of each other or are they cyclically dependent as I explained?
- Are the 4 terms calculated from QM cyclically dependent on each other or are they independent?
Very simple questions to answer, but the answers begin undoing the brainwashing that has gone on.
I also gave a theoretical calculation that violated the inequality. What were you expecting, all that is required is for the assumptions used to derive the inequality to fail in the calculation (whether theoretical or not does not matter).
It is only extreme skepticism to you if you swallow wholesale all the falsehood that is fed to you. I thought for a while that you showed some sound reasoning abilities. If that is still the case, I suggest you write down a list of all the assumptions you think went into the conclusion of non-locality. Including all the hidden ones we have exposed in this thread and at the end explain to yourself, why you are justified in crossing out all of them except the non-locality condition. And don't just cross it out because famous people say it, or because it is popular, because that will not be sound reasoning.
Here is another example, based on the case which Boole actually considered. For this case the Bell-like inequality proposed by Legget and Garg is used. The point is that certain assumptions are made about the data when deriving the inequalities, that must be valid in the data-taking process.
Consider a certain disease that strikes persons in different ways depending on circumstances. Assume that we deal with sets of patients born in Africa, Asia and Europe (denoted a,b,c). Assume further that doctors in three cities Lyon, Paris, and Lille (denoted 1,2,3) are are assembling information about the disease. The doctors perform their investigations on randomly chosen but identical days (n) for all three where n = 1,2,3,...,N for a total of N days. The patients are denoted Alo(n) where l is the city, o is the birthplace and n is the day. Each patient is then given a diagnosis of A = +1/-1 based on presence or absence of the disease. So if a patient from Europe examined in Lille on the 10th day of the study was negative, A3c(10) = -1.
According to the Bell-type Leggett-Garg inequality
Aa(.)Ab(.) + Aa(.)Ac(.) + Ab(.)Ac(.) >= -1
In the case under consideration, our doctors can combine their results as follows
A1a(n)A2b(n) + A1a(n)A3c(n) + A2b(n)A3c(n)
It can easily be verified that by combining any possible diagnosis results, the Legett-Garg inequalitiy will not be violated as the result of the above expression will always be >= -1, so long as the cyclicity (XY+XZ+YZ) is maintained. Therefore the average result will also satisfy that inequality and we can therefore drop the indices and write the inequality only based on place of origin as follows:
<AaAb> + <AaAc> + <AbAc> >= -1
Now consider a variation of the study in which only two doctors perform the investigation. The doctor in Lille examines only patients of type (a) and (b) and the doctor in Lyon examines only patients of type (b) and (c). Note that patients of type (b) are examined twice as much. The doctors not knowing, or having any reason to suspect that the date or location of examinations has any influence decide to designate their patients only based on place of origin.
After numerous examinations they combine their results and find that
<AaAb> + <AaAc> + <AbAc> = -3
They also find that the single outcomes Aa, Ab, Ac, appear randomly distributed around +1/-1 and they are completely baffled. How can single outcomes be completely random while the products are not random. After lengthy discussions they conclude that there must be superluminal influence between the two cities.
But there are other more reasonable reasons. Note that by measuring in only two citites they have removed the cyclicity intended in the original inequality. It can easily be verified that the following scenario will result in what they observed:
- on even dates Aa = +1 and Ac = -1 in both cities while Ab = +1 in Lille and Ab = -1 in Lyon
- on odd days all signs are reversed
In the above case
<A1aA2b> + <A1aA2c> + <A1bA2c> >= -3
which is consistent with what they saw. Note that this equation does NOT maintain the cyclicity (XY+XZ+YZ) of the original inequality for the situation in which only two cities are considered and one group of patients is measured more than once. But by droping the indices for the cities, it gives the false impression that the cyclicity is maintained.
The reason for the discrepancy is that the data is not indexed properly in order to provide a data structure that is consistent with the inequalities as derived.Specifically, the inequalities require cyclicity in the data and since experimenters can not possibly know all the factors in play in order to know how to index the data to preserve the cyclicity, it is unreasonable to expect their data to match the inequalities.
For a fuller treatment of this example, see Hess et al, Possible experience: From Boole to Bell. EPL. 87, No 6, 60007(1-6) (2009) cited at the beginning of this thread.
The key word is "cyclicity" here. Now let's look at various inequalities:
Bell's equation (15) in his original paper:
1 + P(b,c) >= | P(a,b) - P(a,c)|
a,b, c each occur in two of the three terms. Each time together with a different partner. However in actual experiments, the (b,c) pair is analyzed at a different time from the (a,b) pair so the bs are not the same. Just because the experimenter sets a macroscopic angle does not mean that the complete microscopic state of the instrument, which he has no control over is in the same state.
CHSH:
|q(d1,y2) - q(a1,y2)| + |q(d1,b2)+q(a1,b2)| <= 2
d1, y2, a1, b2 each occur in two of the four terms. Same argument above applies.
Leggett-Garg:
<Aa(.)Ab(.)> + <Aa(.)Ac(.)> + <Ab(.)Ac(.)> >= -1
I don't know of any typos (feel free to point them out and we'll fix them), but I am definitely sympathetic to the complaint that the article is too long and in some ways too technical. On the other hand, there is nothing else even nearly as systematic as it out there, so it's good that it exists. But back on the first hand, just because it's good an article like this exists, doesn't mean it should exist as an encyclopedia entry. But hey.
As I have already said, I'm not so sympathetic here. Let's talk first about whether what's in the article is true or not. If it is, then we should be praised for being "biased" in this way, and you can save the complaining for all the other articles that are biased toward false views. On the other hand, if the article is fundamentally wrong, then you might as well just criticize it for that. Either way, the whole issue of "bias" seems like barking up the wrong tree.
I think it would be fair to say that we all deeply appreciate the superiority of Bohmian Mechanics over other extant theories (with the exception of GRW type spontaneous collapse theories, which we also appreciate very much).
Incidentally, the same was true for John Bell. And anybody reading this who is surprised to learn that Bell was a Bohmian needs to quit reading biased secondary literature, and read some actual Bell.
I thought you were talking about the derivation of the CHHS inequality in our paper. The A's there indeed refer to the outcomes of the measurements but there are no *functions* A(a,λ). That implies determinism -- if you specify the λ and the setting, the outcome is determined. We deliberately avoid making such an assumption in that section.
What's an example of a situation where it is violated? I mean, in a real scientific experiment where the experimenters deliberately attempt to avoid any correlation between some "random" setting and some other factor.
Yes, it's clear we disagree about the reasonableness of this premise.
DrChinese said:
I told you that your inference is wrong, and that is because there are explicit models that are non-realistic but local and they feature perfect correlations. For example:
http://arxiv.org/abs/0903.2642
Relational Blockworld: Towards a Discrete Graph Theoretic Foundation of
Quantum Mechanics
W.M. Stuckey, Timothy McDevitt and Michael Silberstein
This approach is similar to the Rovelli relational interpretation of QM. Travis et al discuss relational approaches in their paper and admit that such approaches could potentially be fruitful.
I still can't understand you at all. Where in the world did you get the idea that Bell assumes that the "complete microscopic state" is the same, just because the angle is set the same? Nobody ever made that assumption. Not Bell, not us in the article, not anybody. It doesn't even make any sense. Yet you keep going on as if this is being tacitly assumed.
The point, yet again, is that the *distribution* of these λs is assumed to be the same for the (a,b) type runs, as it is for the (b,c) type runs, etc. There is no assumption, and no need for any assumption, about the actual realized λs always being the same for a certain type of run, that the λs should come in exactly the same order for the different runs, or anything remotely like that.
Sure!
TYPOS, imho; though (granted) some may be a matter of style or for mathematical clarity in the text:
p.5 has "(anti-)correlations" split badly over two lines.
Throughout: Search for space+comma, space+fullstop, space+colon to find incorrect punctuation-spacings.
The 2nd Referee's Report needs editing beyond the above!
Well, for me, its a question of style and emphasis. Your definition of "non-local" gave the game away!
And to say this (too), foot of p.2: "But without any such interaction, the ONLY way to ensure perfect anti-correlation between results on the 2 sides is to have each particle carry a pre-existing determinate value ..., for spin along the z-axis." (My emphasis.)
AND that's a pre-existing infinity of values for such believers, right?
For me: Since the particles are unpolarised (per Bell), conservation of angular momentum (and the dynamics of quantum-style spinning-tops) keeps me away from such travisties: :=))
Also: For me, the probability of any two lambda-pairs being the same is zero? Lambda-pairs being drawn from an infinite set of pairs; triples; etc.
I very much appreciate David Bohm as a person and a physicist; John Bell too; and you! (It's just that I don't do 'weird' very well.)
PS: I look forward to your comments re the "classical challenge".
Regards,
Gordon
I don't know what that is supposed to mean. If anybody has an alternative superior definition of "locality" to propose, I'm all ears.
Yes, the argument establishes that the perfect correlations (along an infinity of possible directions) require an infinity of pre-existing values -- if one assumes locality.
I don't understand. It's not quite right to say the particles are unpolarized. They're in an entangled superposition wrt polarization. Are you saying the statistics can be explained by a local hidden variable theory? That's certainly wrong.
Incidentally, my middle name is "ty" so your pun is quite familiar!
I looked at it briefly. I don't want to get sucked into a whole 'nuther thread. But it seems like your "challenge" involves asking people to calculate what the correlations will be like if the two photons are each in some polarization eigenstates (no entanglement). Of course the correlations will not violate any Bell/CHHS inequality in that case. If you think they do or might, you haven't understood the theorem at all. Also, in general, and returning the favor of your comments about they style of our article, I don't particularly like the style of posing "challenges" with some mysterious "gotcha" obviously waiting in the wings. If you think you've worked out a counterexample to Bell's theorem (which of course is preposterous, but nevermind that for now) then just put it out there and people will look at it and comment. Don't try to make us do your work for you.
This deviates from Bell's view and contradicts what you actually say in the paper:
More precisely, locality requires that some set of data λ — made available to both systems, say, by a common source16 — must fully account for the dependence between A1 and A2 ; in other words, the randomness that generates A1 out of the parameter α1 and the data codified by λ must be independent of the randomness that generates A2 out of the parameter α2 and λ .
Aren't you saying in effect that A1 = func(α1, λ), and A2 = func(α2, λ)? Just because you mention it in words does not mean you do not have functions. The randomness you talk about, which is introduced during measurement could be acounted for by simply assuming another hidden factor (X) such that A1 = func(α1, λ, X1) and A2 = func(α2, λ, X2) in which case A1 = func(α1, λ), A2 = func(α2, λ) may appear random and non-deterministic.
I have given you two examples, one with coin tosses, another with doctors and patients. It is up to you to show the conspiracy in the two examples I gave that resulted in the violation.
This demonstrates a misunderstanding. In, the analogy I mentioned about flipping a coin and picking an individual randomly from physicsforums members. What if the experimenter knew nothing about the "hidden" parameter that the pool of people from which he was picking were members of a physics forum, how would he be able to make sure he has sampled randomly? Your error is to think that randomization enables you to screen-off any variable which you know nothing about.
Bell in his original 1964 paper said:
Since the initial quantum mechanical wavefunction does not determine the result of an individual measurement, this predetermination implies the possibility of a more complete specification of the state.
Let this more complete specification be effected by means of parameters λ. ...
It is obvious therefore from what you have accepted already in this thread that if the distribution of λ is the same in each run of the experiment, this means precisely that the *complete specification* of all the hidden parameters which resulted in the outcomes for that run, i.e, the list of all the actually realized λi values must be identical from one type of run to another. It doesn't matter in what order they appear in that list, all that matters is that they MUST in principle be sortable so that they now have the exact same order. This is what it means for the distribution to be identical. You agreed to this already!?
If you are now disagreeing with this then you are in effect saying you do not have any justification to factorize within the integral as you did. You cannot factorize a function and at the same time claim that the domain of the function was different from one term to the next. This can not be any clearer.
First of all, I never said the order must be the same. I said the lists must in principle be sortable so that they have the exact same order. What do you think the domain of integration means for all the terms within the integral? That is why I used the discrete example so that you can understand the operation in terms of a list. If the domain of integration corresponds to 100 discrete λ values, then each function within the integral has the exact same domain of those 100 discrete values: λ1, λ2, ... λ100. If within the integral you have [E(a,λ)*E(b,λ) + E(a,λ)*E(cλ)]*p(λ), it is very clear that in the integral we performing an operation similar to:
[E(a,λ1)*E(b,λ1) + E(a,λ1)*E(cλ1)]*p(λ1)
+ [E(a,λ2)*E(b,λ2) + E(a,λ2)*E(cλ2)]*p(λ2)
+ [E(a,λ3)*E(b,λ3) + E(a,λ3)*E(cλ3)]*p(λ3)
+[E(a,λ100)*E(b,λ100) + E(a,λ100)*E(cλ100)]*p(λ100)
Now if you factor the terms the way you did within your integral to get something like:
[E(b,λ) + E(cλ)]*E(a,λ)*p(λ)
It is implicit that the exact domain of integration λ1, λ2, ... λ100, applies to each term and the same distribution p(λ1), p(λ2), p(λ3), ..., p(λ100) applies to each term. If that is not the case, then you have absolutely no justification for doing the factorization in the first place! Note the result of the factorization is that we end up with only 3 lists of numbers from which we could build the original paired products:
E(a,λi), i=1, 2, ... 100
E(b,λi), i=1, 2, ... 100
E(c,λi), i=1, 2, ... 100
Note also that, we could replace the probability weighted sum with a simple average by assuming that the domain of integration was not λ1, λ2, ... λ100, but rather a large number of trials in which the λs were realized at relative frequencies corresponding to their probability. In any case, once we have defined the domain of integration, it applies to every term within it. And we will still end up with ONLY 3 lists of outcomes in this reduced example.
These are the conditions which allow you to derive the inequality. These conditions must be true for the experiment to be used as a source of terms for the LHS of the CHSH. For the data from the experiment to be usable, the 8 lists of outcomes (4-paris) MUST be reduceable to 4 lists. Do you agree or disagree, you still have not answered this question.
Can I make it any simpler than that?
I think this is an unimportant side issue, but writing A(a,λ) implies that there is some definite value of A that will be produced when the setting is a and the ... whatever ... is λ. That assumes determinism and is unnecessary in the derivation, so instead one should just say that the probabilities for the (two) possible values of A are determined jointly by (a,λ).
Sample a bunch more and see if the statistics change.
You're not getting the point. The burden of proof lies on the other side, so to speak. We're talking about the kind of situation where, by ordinary scientific reason, you'd need some special reason -- some evidence -- to even suspect the kind of thing that you, instead, think should be assumed to exist until/unless there is some proof that it isn't happening. So it's not that I think that "randomization enables you to screen-off any variable you know nothing about" -- it's rather that the very idea that something is suitably "random" means that it isn't correlated up, in some fine-tuned way, with other things. This is never the kind of thing that can be proved in the way you seem to demand; rather it is a normal (and, usually, completely uncontroversial) background assumption lying behind the very project of empirical science.
All it means for the distributions to be identical is that the lists have the same relative frequencies for the different values of λ (suitably coarse-grained if that's appropriate in the context of a given theory). Note that there is no reason we have to even measure the same exact number of particle pairs for the different joint settings! So surely it's way to strong to be insisting that "the lists have to be exactly the same" in the sense you describe here.
Yes.
I don't understand your point. The factored thing you just wrote here means (following your notation from above)
[E(b,λ1)+E(c,λ1)]*E(a,λ1)*P(λ1)
But it sounds like you think this sum is somehow different than what you wrote above. Of course it is not. ?
Why do you say this is a "result of the factorization"? It was already true that only these three functions were present. We just did ... trivial algebra. ?
You'll have to, as I don't understand. It sounds as if you're objecting to something that is, literally, a trivial piece of elementary algebra: factoring a common factor out of a binomial expression. I can't tell if that's your actual worry, or if instead you think that that's OK as math, but that somehow the experiments don't "live up to" the math.
Einstein's definition of "local" works just fine for me.
The argument is weak, imho. (Recall that I am offering my views on your article.) I believe it shows the authors' bias. I personally accept Einstein-locality with no need to accept what your "argument" purports to be the consequences.
So why did Bell emphasise that the particles are unpolarised?
It seemed to me that he was making an important point?
As to the statistics, see below.
My apologies. I tried to edit it out but was too late.
As for style, my OP re "The Challenge" was presented as a question.
We now come to the matter of statistics and your failure to respond to a simple challenge.
I am not asking you to be "sucked-in" to another thread. I brought the challenge here, in what I thought was the spirit of the OP.
I would like to see the challenge addressed in the context of your article.
I was redrafting the introduction to the article for discussion here (seeking to be helpful). I was planning to show how I (a non-Bohmian) sees the challenge of BT.
So, I thought: What better place to start than with a realistic and Einstein-local (i.e., a wholly classical; and easily conducted) experiment?
But it seems that your imagined "Gotcha" has indeed GOTCHA! To be clear, I'm not asking you to do anything except give me your best thoughts on the challenge in the context of your article.
Your group holds themselves out to have some expertise re Bell's Theorem.
I would like to see that expertise applied to a realistic and Einstein-local (i.e., a wholly classical; and easily conducted) experiment?
So, please, do the maths or say why you cannot.
Is that too much to ask? Or too big a task?
But that is the point you continue to fail to understand. The fact that the statistics does not change does not mean the statistic you have is the appropriate one you are trying to calculate for the problem you have at hand! It's like trying to measure the average height of 100 people and you decide to measure 1 person's height 100 times. Just because your average converges does not mean you are calculating the correct average.
On the contrary, it is you who do not get the point. You are the one doing the factorization to obtain the inequality, and then using experimental data, which do not obey the factorization requirements implicit in the derivation. It is up to you to demonstrate that the data you are comparing with the inequality is factorable. I have given you two examples in which the data was not factorable and the inequalities were violated without any conspiracy. One counter-example is enough to show how unreasonable your "no-conspiracy" assumption is. I gave you two.
I have explained from your proof and you have agreed that the terms in the CHSH are not independent of each other due to the cyclicity that permits you to do the factorization. Yet you take completely independent terms from QM and plug them into the LHS of the CHSH violating the very requirement which enables you to derive the inequalities. But for some reason, you translate this mathematical error on your part to the conclusion that locality is false.
First of all, it is not clear what you mean by suitable random. Secondly, in case you did not know, "random" simply means unpredictable. It doesn't mean there is no correlation. It simply means based on what you know, you can not discern a correlation. A system may appear random to one person and correlated to another who has more information about what is happening. But this is beside the point since the two examples I gave about doctors and coins decimates this line of argument of yours.
Even if we grant you the suggestion that the lists don't have to be the same length but only possesses the same relative frequency of each distinct λ value? You still can not escape because you already admitted that there is no way for the experimenters (having no information about λ) to make sure the same relative frequencies of λ are realized in the three different runs of the experiment. So there is no way to fulfil this requirement experimentally. As demonstrated by the examples I have illustrated,an infinite number of blind trials without any information of the parameters does not automatically give you the same λ distribution. In fact this can easily be seen by assuming that some combinations of λ and instrument settings lead to non-detection of the particle such that the coincidence circuitary discriminates against some λs by eliminating them from being considered for some angles. This will in fact cause you not to have the same λ distribution for each run. Do you think this is unreasonable? What is the conspiracy here?
I'm not insisting. It is you who unknowinglys is insting that they must be, simply by carrying out the "trivial" algebra which you did in order to derive the inequality. I'm simply pointing out to you the implications of your "trivial" algebra. At least now you recognize that experiments can not fulfill this requirement which you relied on to derive the inequality.
Exactly, you have only three (or 4 terms in the CHSH case) terms in deriving the inequality, but you do not have only 4 terms from an experiment, you have 8 terms in the form of lists of values. And those 8 terms cannot be reduced to 4 as required by your derivation. Get it?
Just in case you still do not understand, you derive the inequality starting with ONLY 4 terms E(a), E(b), E(c), E(a'). In the experiment you perform 4 separate runs (1,2,3,4). In the first you measure E1(a) and E1(b), in the second you measure E2(a) and E2(c), in the third you measure E3(a') and E3(b) and in the fourch you measure E4(a') and E4(c). In order for the terms from the experiment to comply with the requirements used in deriving the inequality,
E1(a) = E2(a)
E1(b) = E3(b)
E2(c) = E4(c)
E3(a') = E4(a')
This is the only way we end up with 4 terms like you used in your inequality. Note E(a) is a function not a number and saying two functions are equal means their codomain is identical for the same domain. And since you have already accepted that the domain of the function is the distribution of λ which is identical for each term, the outcomes of these functions must also be identical.
However, looking more carefully, you realize that the use of coincidence circuitary imples that in fact what is being measured is not E1(a), E2(a), E1(b), E3(b), E2(c), E4(c), E3(a'), E4(a') but instead
E1(a|b), E1(b|a) ie, the outcome at A1 with setting a, given that an outcome was also registered at A2 for setting b, etc
E2(c|a),E2(a|c),
E3(a'|b),E3(b|a'),
E4(a'|c), E4(c|a')
Which complicates things even further because now the requirement is that the following equalities must hold for the data to be usable on the LHS of the CHSH
E1(a|b) = E2(a|c)
E1(b|a) = E3(b|a')
E2(c|a) = E4(c|a')
E3(a'|b) = E4(a'|c)
So then, keeping in mind that the distribution of actually realized λ must be identical for all 4 terms. All you need for the experiment to violate the inequality is for any of the above equalities to be false, OR for certain λ values to be excluded from consideration by the coincidence circuitary for certain pairs of angles.
From what we know classically from Malus law, it is reasonable to expect the rate of coincidence detection to change with the angular difference and no amount of infinite trials can remedy this difficulty.
THe experiments don't live up to the math. It is so simple you could not see it. The error is hiding in plain sight. It might be trivial algebra, but many have been fooled by it. That is why you can't just gloss over it. Just in case you misunderstand again, I'm not questioning the algebra, I'm showing you the implications of it.
Here is an article which analyzes data from the Weihs et. al. experiment and show that there is a variation in coincidence count rate with angle (fig1) although single count rates do not vary with angle (fig3).
Which simply demonstrates that E(a|b) is different fro E(a).
http://arxiv.org/pdf/quant-ph/0606122
Look for example at figure 1. They say:
As can be seen in the coincidence rate figures (see figure 1a),
the coincidence rates exhibit minima close to zero, and cosine-squared shape, as
expected from the predictions of Quantum Mechanics. However, the maxima of the
four coincidence curves differ significantly. In spite of this anomalous behavior, the
correlation function computed with the standard normalization (i.e., with the sum of all
coincidence counts) coincides very well with the quantum mechanical predictions (see
figure 1b).
It is interesting to note that possibly similar anomalies were observed first in the
two-channel EPR experiments performed by Alain Aspect in Orsay in the early 1980’s.
The anomalies were reported in Aspect’s PhD Thesis [15] in the following words
For some measurements, we have observed abnormal differences between
coincidence rates that were expected to be equal (for instance N+− and N −+ ). It
turns out however that even for these measurements the correlation coefficient
E(a, b) remains equal to the quantum predictions, with better than two standard
deviations. We have no completely convincing explanation, either for these
anomalies, or for their compensation
The no-signalling principle being a fundamental feature of Quantum Mechanics, as
well as of Local Realism, the most reasonable interpretation of these anomalies is that
the Fair Sampling assumption should be rejected, as it is the only extra assumption
that we used to observe them.
Gordon, Sorry but I'm not interested in engaging with these kinds of games. The sort of model you are toying with -- an obviously local model -- is going to make predictions that respect Bell's inequalities. You apparently think there is some big surprise waiting here, but there isn't. And if I'm wrong, I'm sure I'll hear about it when you present your results.
Bill, I think we have to agree to disagree about the reasonableness of the "no conspiracy" assumption. Your most recent (long) message does help me (to some extent) to understand what you are and aren't bothered by -- namely that it's the experiment "not living up to" the math as opposed to the math itself. But I still think you are profoundly wrong in how you are thinking about what the experiments are and/or should be. You are thinking of them as attempts to somehow recapitulate the steps in the derivation of the inequality. The truth is that the experiments simply measure the correlations, while the theorem is a proof that (under certain assumptions) the correlations are constrained in a certain way. There is simply no reason these two things should "look like each other" in anything like the way you seem to be demanding.
Thanks both for the stimulating discussion!
Games? Is that what I was involved in when seriously annotating your article for comment?
Surprise? I'm surprised at your response (but should not have been).
But surely the big surprise is that YOU have so far been unable apply Bell's local-realistic protocol to a local-realistic experiment!
PS: The model that I'm employing is Bell's (1964) mathematical model of local-realism. I'm interested in how it fares in the analysis of a clearly local-realistic experiment.
