Scrodinger equation and Quantum mechanic stuff required
  • Thread starter Thread starter KKtm
    Mechanic Quantum
KKtm
Apply Schrodinger’s Wave equation to calculate energies of particle in a box .
kindly refer me to some web material and send some stuff regarding it , also if some one has the PDF files related to Quantum mechanics with solved examples... would be immense help.
Regards
Are you using a book to learn quantum mechanics?
You should know that
\hat{H}\Psi = E \Psi
So all you have to do is solve the PDE for a particle in a box. Is your box infinite, or finite? If it is finite you would have to solve the problem numerically, which is more work, but still not too difficult.
So this is actually a really easy problem. All you do is take the Schrodinger Equation:
-\dfrac{\hbar^2}{2m}\dfrac{d^2\psi}{dx^2}+V(x)\psi(x) = E\psi(x)
Now you plug in the potential. This can be centered at 0, but it's usually more easily centered at L/2, where L is the well width. The potential is,
V(x) = 0 when 0<x<L, and
V(x) = \infty when x<0 or x>L
So inside the well you've just got:
-\dfrac{\hbar^2}{2m}\dfrac{d^2\psi}{dx^2} = E\psi(x)
Or,
\dfrac{d^2\psi}{dx^2}+ \dfrac{2mE}{\hbar^2}\psi(x)=0
What does this look like? Hint: it's exactly the same mathematical form as the simple harmonic oscillator from classical mechanics (but it doesn't actually have anything to do with oscillators physics-wise). You should be able to solve the equation using the ansatz,
\psi(x) = Asin(kx) + Bcos(kx)
The value of k is found from the boundary conditions. Remember that the potential outside the well is zero. Thus the wavefunction has to either be 0 or infinity at those places. Common sense dictates it'll be zero, so the wave has to "fit" inside the box. Thus the wavenumber will have to be such that the wave always goes to zero at the boundaries. This eliminates all cosine solutions, since cos(0)=1. You can figure out what k is. From that you can solve for the energy. And if you really want, you can figure out what A is by finding the complex modulus squared of psi and treating it as a probability density.
Let me know what you come up with!
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
