SCSI vs IDE: Why SCSI HDDs Cost More
  • Thread starter Thread starter Saint
SCSI hard drives are generally more expensive than IDE drives due to their faster data transmission rates, despite having similar capacities and RPMs. SCSI technology allows for greater flexibility, supporting up to 15 drives in a system compared to the 4-device limit of IDE, which is particularly beneficial in server and graphic workstation environments. Additionally, SCSI drives often include RAID capabilities, enhancing data redundancy and performance. While IDE drives can also implement RAID configurations, SCSI's design allows for hot-swapping, enabling users to replace failed drives without shutting down the system, minimizing data loss. SCSI typically requires an additional adapter card, as most motherboards do not natively support it, except in server setups. Overall, SCSI's advantages in speed, flexibility, and reliability contribute to its higher cost compared to IDE drives.
Saint
why SCSI HDD is more expensive than IDE HDD? The capacity and spinning speed are the same, but price varies.
Computer science news on Phys.org
The capacity and r.p.m. may be the same, but SCSI transmits the data faster, hence the larger price.
(edit: Also, I believe, RAID capability is usually incorporated with SCSI.)
You often need an additional adapter card as well, since most motherboard manufacturers don't include SCSI capability except for servers.
SCSI is faster. But you should try S-ATA, I heard it really rocks...
scsi is more flexible then ide. you can only have 4 ide drives in a system vs. 15 scsi drives in a system, which can be important in a server or a graphic workstation. one reason why servers use scsi is that is one of the hard drives goes, you can keep doing what ever it was you were doing and replace the drive without turing off the systen, and with a good backup program program you lose very little data
You can do that with IDE as well, Raid 5 - Stripe set. This feature is not a part of scsi hard drives, but may be a part of the scsi controller card depending on what you buy.
I personally have not seen an IDE drive spinning at 10k rpm. 7200 is the fastest I have used.
As far as the 4 device IDE limit, you can buy IDE expansion cards that allow you more devices.
SCSI is faster than a normal IDE drive...I have not seen any S-ATA devices, I'll have to go check that out
This week, I saw a documentary done by the French called Les sacrifiés de l'IA, which was presented by a Canadian show Enquête. If you understand French I recommend it. Very eye-opening. I found a similar documentary in English called The Human Cost of AI: Data workers in the Global South. There is also an interview with Milagros Miceli (appearing in both documentaries) on Youtube: I also found a powerpoint presentation by the economist Uma Rani (appearing in the French documentary), AI...
Thread 'Urgent: Physically repair - or bypass - power button on Asus laptop'
Asus Vivobook S14 flip. The power button is wrecked. Unable to turn it on AT ALL. We can get into how and why it got wrecked later, but suffice to say a kitchen knife was involved: These buttons do want to NOT come off, not like other lappies, where they can snap in and out. And they sure don't go back on. So, in the absence of a longer-term solution that might involve a replacement, is there any way I can activate the power button, like with a paperclip or wire or something? It looks...
