Second Order Differential Equation to show s = ut +(1/2)at^2
7 replies · 7K views
Woolyabyss
If d^2s/dt^2 = a, given that ds/dt = u and s = 0, when t = 0, where a, u are constants
show that s = ut + .5at^2
2. The attempt at a solution
du/dt = a
cross multiplying and then integrating and we get
u = at
ds/dt = at
cross multiply and integrate
s = .5at^2
using limits when t = 0 then s = 0
I can't seem to get out the constant u
could you maybe use v = u + at ? and say v = u + at but v = ds/dt
so ds/dt = u + at
cross multiplying and integrating and you get
s = ut + .5at^2
Yes, but first you need to derive this from the starting equality d2s/dt2 = a.
I'm not sure how though could I say dv/dt = a
and then I'd get v = at but I just can't seem to get the u.
u = at
After integration there's a constant. Say the initial velocity is u0, then
u = at + u0
The problem statement seems a bit off, if u = ds/dt, then there needs to be a constant for initial velocity in the equation such as u0:
s = u0 t + 1/2 a t^2
u = at + u0
But would using the limits not eliminate the constant of integration?
The goal here is to produce a quadratic equation, not an intergral with limits.
I got now thanks.
