How Do Formulas for Sector Area and Arc Length Relate?
The formulas for sector area and arc length relate through the measurement of angles in radians and degrees. The area of a sector is given by K = (1/2)sr, where "s" is the arc length and "r" is the radius, while the arc length is calculated as s = Θr. The confusion arises because the commonly known area formula A = (Θ/360)πr² is in degrees, whereas the first formula uses radians. By recognizing that 360 degrees equals 2π radians, both formulas can be shown to represent the same concept. Understanding the relationship between radians and degrees clarifies how to apply the appropriate formula based on the angle measurement.
frozonecom
I'm just wondering because I'm really confused right now.
My teacher gave us the formula:
K= \frac{1}{2}sr
for area of a given sector where "s" is the arc length and "r" is the given radius.
the formula for the arc length is:
s=\Theta r
Though, I can't seem to understand how he came up with the formula for the area of the sector, because searching the internet always came with the result that the formula for area of the sector is:
A= \frac{\Theta}{360} \pi r^2
I hope someone can help me. :)
Mathematics news on Phys.org
Your first formula is measured in "radians". A full revolution is 2*pi radians.
Your last formula is measured in degrees. A full revolution is 360 degrees.
Multiply your last formula by 1 in a clever way: 1 = (360 degrees)/(2*pi)
Oh! So both formulas are actually the same.
The difference is just that I'll use the "right formula" based on the given theta!
Thanks! :)
Here's an easy way to think of it. You know that the area of a circle is pi r^2, right? So, think of the circle as a "sector" of angle 360 degrees, or 2pi radians. You need to multiply the angle by whatever factor will give you the result pi r^2. And then that factor is the same for any other angle measured in the same units.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
