Seeing if something is Dimensionally correct.
  • Thread starter Thread starter Sirsh
The discussion focuses on verifying the dimensional correctness of the terminal velocity equation Vt = (2mg/pA)1/2. Participants analyze the units involved, noting that mass (kg) cancels out during simplification, leading to confusion about the presence of the constant "2." It is clarified that dimensional analysis primarily checks units, and coefficients like "2" do not affect dimensional correctness. The conclusion reached is that the equation is not dimensionally correct as presented, prompting further exploration of the calculations. Overall, the conversation emphasizes the importance of correctly handling units in dimensional analysis.
Sirsh
Vt = (2mg/pA)1/2
where:
Vt = Terminal Velocity (ms-1) as velocity = s/t = m/s(seconds, not distance).
m = mass in kg.
g = gravity in ms-2.
p = fluid density in kgm-3
A = Area in m2
Show that equation is dimesionally correct.
I seem to get my answer wrong on the end product; ill show my working up too where I've got my answer incorrect.
Vt = (2mg/pA)1/2
m/s = (2(kg)(m/s2)/(kg/m3)(m2))1/2
(m/s)2 = (2(kg)(m/s2)/(kg/m3)(m2))
(m/s)2 = (2(kg)(m4)/((kg)(s2)(m2))
(m2/s2) = ((kg)(m2))/(s2)
As you can see the equation is quite simplified at this point, with the only problem being that both left and right sides do not equal, which shows that the equation is not dimensionally correct, i am unsure though how to get rid of this unit of kg in my equation though. can anyone help me out on this one, thanks alot!
Why didn't you cancel out the kilograms at any point? From the get go, it cancels out.
If i cancle the kg out, then i am stuck with a '2' in the final equation instead of a kg unit. because if i try cancle the 2 out by halving that side, then the other side (left hand side) gets 2 in the denominator :/
I'm not completely sure about this, but does the "2" even matter in dimensional analysis? I believe dimensional analysis is just to check the units. The coefficient isn't involved or checked.
Good point! ill check that up!
