Seeking Confirmation On An Equation's Answer
  • Thread starter Thread starter Glynbeard
The equation presented is (3|(sqrt(2log4(16)) - (3*5^2))|+1)/(11/4). The user calculated the value as 80 and confirmed this using WolframAlpha. Another participant clarified that the expression simplifies to 80 through step-by-step calculations. The breakdown shows that the absolute value and logarithmic operations lead to the final result. Therefore, the user's answer of 80 is confirmed as correct.
Glynbeard
or
http://www.freemathhelp.com/forum/attachment.php?attachmentid=1719&d=1329600509&thumb=1
Listed above.
I solved through the above equation and got the answer to be 80 and I was wondering if this is correct. When I plug it into wolframalpha, I get 80 as well (as seen here), but I just want to be sure before moving forward.
Any help would be greatly appreciated!
That is not an equation, it is an expressdion! If you are simply asking for its value,
2 log_4(16)= 2(2)= 4 sqrt(4)= 2 3*5^2= 75
2- 75= -73. 3|-73|= 219. 219+ 1= 220. 220*(4/11)= 20*4= 80 so, yes, you are correct.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
