Selection of Right Lipo battery
  • Thread starter Thread starter bhaazee
    Battery Lipo
Selecting the right LiPo battery involves understanding motor specifications, such as the Kv rating, which indicates RPM per volt, and the maximum continuous current and power requirements. A 12s battery configuration means a 12-cell setup, with each cell typically at 3.7 volts, totaling approximately 44.4 volts. The discussed battery, rated at 5000mAh and 10 cells, can theoretically deliver about 185 watts for one hour, but this does not meet the motor's high continuous current demand of 115 amps. Finding a suitable battery that can sustain the motor's requirements for an hour or more may require extensive research through battery catalogs. Understanding these calculations and specifications is crucial for effective battery selection.
bhaazee
I would like to know about selecting the proper lipo batteries. For example, for the following motor spec a suitable battery has to be selected
Motor Kv 540KV RPM/Volt
(What does KV in 540KV represent?)
Max Continuous Current 115 Amps
Max Continuous Power 4800 Watts
Max Lipo Cell 12s
(Does 12s means a 12-cell battery?)
Now assume the following battery spec
LiPo Battery 5000mAh 10-Cell 37V
Does this mean the battery can supply a 5 Amp-hr *37 volt * 10 cells = 1850 watt-hr?
How to find how long this battery can be used to power the above motor?
(I would like to choose a suitable battery that can run the motor for 1 hour or more)
My query might be childish. However, would like to to learn something. Can someone please explain me with simple calc?
Regards
The battery of 10 cells deliver 37 volts, so they are 3.7 volts each.
The output could be 5 amps for an hour (5 AH) and, in this case, the power would be (37 volts times 5 amps) or 185 watts assuming the battery voltage did not drop appreciably in this time.
The motor specifications are confusing. KV clearly does not mean Kilo-Volts here so you would have to seek further clarification.
However, the motor is apparently getting 41.7 volts from the battery so it could be a 12 cell battery. This would make each cell 3.47 volts which seems about right.
The current of 115 amps continuous is very high and you would have to hunt through catalogs to find something suitable.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
