Self locking gears for parabolic solar concentrator
  • Thread starter Thread starter Renato1
    Gears Self Solar
Using a self-locking gear, such as a worm gear, is a viable option for a solar tracker system on a 2-ton parabolic mirror dish, provided the reduction ratio is sufficiently high. While worm gears can effectively stop the dish at a specific angle to maintain alignment with the sun, additional braking systems may be necessary to handle inertial loads. Alternatives to worm gears include ball screws, which offer low friction but lack self-locking capabilities. Proper mounting on an equatorial mount is recommended for balanced tracking, with manual elevation adjustments every few days. Overall, careful consideration of gear types and mounting strategies is crucial for effective solar tracking.
Renato1
Hello everyone, my question is: Would be ok to use a self locking gear like a worm gear for a solar tracker system on a 2 ton parabolic mirror dish? Would it be necessary some kind of brake system, or the worm gear would be enough?
If so, are there any type of self locking gears besides the worm gear?. The idea to use a self locking gear is to stop the dish at a certain position and angle, so that the dish is perpendicular to the sun, and the lock would stop the inertial load (parabolic dish) from back driving the system.
Also I have been thinking about the garage door opener systems, does anyone know how the system is locked and cannot be opened by simply pushing or pulling the door? Is the worm gear the thing that make it impossible to open the door by force?
If you have had experience in positioning systems like big satellite dishes, antennae or parabolic solar concentrators (Solar trackers) what would be your suggestion to drive the system (actuators and transmission mechanism).
Thank you in advance for your time.
RM
Welcome to PF.
Some worm gears are self locking, others not, the type of lubricant makes a difference.
A worm gear will lock if the reduction ratio is high enough.
Ball screws are low friction and so good for positioning. But they are certainly not self locking.
The first thing I would do is to mount the dish so it is balanced in declination and right ascension on an equatorial mount.
Continuously track in RA during the day. Elevation can be done by hand each few days.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
