Semi-major axis from cartesian co-ordinates
  • Context: Undergrad
  • Thread starter Thread starter Spanky Deluxe
    Axis Cartesian
The discussion revolves around calculating the semi-major axis of a body in an elliptical orbit using Cartesian coordinates (x, y, z) and velocity components (vx, vy, vz). Participants explore various methods and equations relevant to orbital mechanics, including the eccentricity of the orbit.
  • One participant asks how to calculate the semi-major axis given Cartesian coordinates and velocity components, expressing uncertainty about the necessary conversions.
  • Another participant suggests that Keplerian orbits can be treated as two-dimensional, implying that z and vz can be ignored, but this is contested by others.
  • Some participants emphasize the need for the gravitational constant (G*M) to calculate the semi-major axis and mention the relationship between specific angular momentum and the semi-major axis.
  • There is a discussion about using the specific angular momentum and eccentricity vector to derive the semi-major axis and eccentricity, with formulas provided for both.
  • One participant notes that they are obtaining different results for the semi-major axis using different equations, despite consistent results for eccentricity.
  • The vis-viva equation is mentioned as a key to solving the problem of finding the semi-major axis.
  • Corrections are made regarding the relationship between angular momentum and the semi-major axis, indicating a potential misunderstanding in earlier claims.
Participants express differing views on whether z and vz can be ignored in the calculations. There is also a lack of consensus on the correct relationship between angular momentum and the semi-major axis, as some participants correct earlier statements while others maintain their positions.
Some participants highlight the importance of the gravitational constant and the specific angular momentum in the calculations, but there are unresolved issues regarding the correct application of formulas and the separation of eccentricity from the semi-major axis.
Spanky Deluxe
Can anyone suggest how to calculate the semi major axis of a body in an elliptical orbit when all I've got is x,y,z,vx,vy and vz?
I'm guessing I need to calculate the eccentricity too. I really suck at conversions like this. :(
Astronomy news on Phys.org
Keplerian orbits are all two-dimensional, so you don't need to worry about z or vz; they can be defined as 0.
Take a look at http://en.wikipedia.org/wiki/Orbit#Analysis_of_orbital_motion, especially the equation at the very end. Provided you know the mass & position of the body being orbited, the semi-major axis (a) can easily be calculated.
You better have at least one other thing. You need to know the body's gravitational constant, G*M, which are often combined as a single parameter μ.
Hint: How is the specific angular momentum related to the semi-major axis?
Hint: You need to calculate the eccentricity.
No, they can't. He is given non-zero values. Ignoring them *will* yield the wrong answer.
Yes, if you're actually given a set of positions and velocities in all dimensions, you can't ignore one of them. Ignoring z and Vz only works if you get to arbitrarily define your coordinate system, in which case you can set both to 0.
aha, so I can use:
[tex]\textbf{h}=\textbf{r}\times\textbf{v}[/tex]
to find the specific angular momentum and then
[tex]a\left(1-e\right)=\frac{h^{2}}{GM}[/tex]
But then how can I separate the eccentricity and semi-major axis?
Simple: Compute the eccentricity vector and take its magnitude. So what's this eccentricity vector thing?
[tex]\vec e = \frac{\vec v \times \vec h}{GM} - \frac{\vec r}{||\vec r||}[/tex]
Ok, I've done that now.
One thing though, I also found the following equations which I found http://microsat.sm.bmstu.ru/e-library/Ballistics/kepler.pdf :
[tex]a=\frac{GMr}{2GM-rv^{2}}[/tex]
and
[tex]e=\sqrt{1-\frac{h^{2}}{GMa}}[/tex]
I've tested both sets of equations and I get the same numbers for the eccentricity, which is good. However, I'm getting different results for the semi major axis. :(
http://photos-d.ak.fbcdn.net/hphotos-ak-snc1/hs017.snc1/4224_95107990559_95107705559_3010885_4034015_s.jpg
The vis-viva equation, doh!
[tex]v^2=GM\left(\frac 2 r - \frac 1 a\right)[/tex]
I was thinking to much of your problem in term of converting cartesian position and velocity to orbital elements (six of them). The specific angular momentum and the eccentricity vector are the keys to unlocking that puzzle. However, all you wanted was the semi-major axis. The vis-viva is the key to answering that particular problem.
That's because you have the relation between angular momentum wrong, here:
That should be
[tex]a(1-e^2) = \frac {h^2}{GM}[/tex]
DH, you are an absolute star and a lifesaver! Thanks so much for the help!
14K
  • · Replies 18 ·
