Sequence is convergent if it has a convergent subsequence
gottfried
Show that an increasing sequence is convergent if it has a convergent subsequence.
Suppose xjn is a subsequence of xn and xjn→x.
Therefore \existsN such that jn>N implies |xjn-x|<\epsilon
It follows that n>jn>N implies |xn-x|<\epsilon
Therefore xn→x
The solution that I've been given is much more complicated I'm just wondering whether my simpler solution is also correct.
It's true, but WHY does it follow? This is the key part of the proof, so you need to be explicit. You need to use the fact that x_n is an increasing sequence. This would not be true for an arbitrary sequence.
The original question was an 'if and only if question' which means the reverse also had to be proved ie:
Show that if xn → x that any subsequence of (xn) also converges to x
My solution which is simliar to the answer given is
If xn → x then given any  \epsilon> 0 there is an N such that n > N implies |xn - x| < \epsilon . Now
consider a subsequence (xjn). Then since jn \geq n > N we have that for any n > N,
|xjn - x| < \epsilon  and so we conclude that the subsequence has the same limit
I believe this correct and this raises the question why does logic work in the one direction but no the other.
It does work in both directions. If EVERY subsequence of x_n converges to x, then x_n converges to x. This is trivial, because x_n is a subsequence of itself.
But the hypothesis in the first part is weaker: x_n has *a* convergent subsequence. Without the additional assumption that x_n is increasing, this would not be enough to conclude that x_n converges.
A general sequence can have some subsequences which converge, and others which do not. For example, let x_n = 0 if n is even, and x_n = n if n is odd. The subsequence consisting of even indices converges, and the subsequence consisting of odd indices diverges. And of course the sequence itself does not converge.
Thanks it makes sense.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
