(Serbia) Just squaring won't work
  • Thread starter Thread starter Dinheiro
    Work
The discussion revolves around solving the equation x = √(2 + √(2 - √(2 + x))). Participants explore various algebraic manipulations and substitutions, including the use of trigonometric identities, to find a solution. It is established that the function f(x) = √(2 + √(2 - √(2 + x))) is strictly decreasing on the interval [√2, 2], indicating that there is only one real root in this range. Although the equation is complex and leads to a polynomial of degree 8, numerical methods or software like Maple can be employed to identify the roots, with only one being relevant to the original problem. Ultimately, the conversation highlights the challenges of finding an exact solution without computational tools.
Dinheiro
Find the real solution x = \sqrt{2+\sqrt{2-\sqrt{2+x}}}
Algebric equations
I tried to find some kind of recurrence by expanding as follows:
2 - x = 2 -\sqrt{2+\sqrt{2-\sqrt{2+x}}}
\sqrt{2-x} = \sqrt{2-\sqrt{2+\sqrt{2-\sqrt{2+x}}}}
then
2+\sqrt{2-x} = 2 + \sqrt{2-\sqrt{2+\sqrt{2-\sqrt{2+x}}}}
\sqrt{2+\sqrt{2-x}} = \sqrt{2 + \sqrt{2-\sqrt{2+\sqrt{2-\sqrt{2+x}}}}}
but I couldn't identify any, so I tried some substitutions and no solution yet :p
How should I do this?
Note: no calculators allowed
Just out of curiosity, what does Serbia have to do with this?
It is a Serbian olympic question. I thought indicating its origin would help finding a solution though
Algebric equations
then
You can analyze some general properties of the solution, but getting the solution itself is challenging. Let ##f(x) = \sqrt{2+\sqrt{2-\sqrt{2+x}}}##, so the equation is ##x = f(x)##. In order for all square roots defining f(x) to be real, we need ##2 \geq \sqrt{x+2}##, hence ##x \leq 2##. Also, ##f(x) \geq \sqrt{2}## (because ##f(x) = \sqrt{2 + \text{something} \geq 0}##) , so ##x \geq \sqrt{2}##. Note that ##f(\sqrt{2}) > \sqrt{2}## and ##f(2) = \sqrt{2} < 2## so there IS a root between ##\sqrt{2}## and ##2##.
Getting an exact root can be done, but I don't see how without using a computer algebra package. Squaring DOES work, but it introduces 7 extraneous roots that are not part of the original problem.
x = f(x) \: \Longrightarrow x^2-2 = \sqrt{2 - \sqrt{2+x}} \: \Longrightarrow<br /> (x^2-2)^2 = 2 - \sqrt{2+x} \: \longrightarrow x+2 = (2 - (x^2-2)^2)^2
This is a polynomial equation of degree 8. Packages like Maple or Mathematica can find all the roots, but they are complicated. Only one of the roots lies in the region ##[\sqrt{2},2]##.
I have been at this problem for about half an hour now, and couldn't deduce much beyond what you said, Ray. But I am curious to know how you deduced there is only one root in the region [\sqrt 2,2]. I think there is at least one other real root(assuming the others are complex), which may be in that range, right?
You can determine that any real root must be in that interval by considering the following.
You have ##\ \sqrt{2+x} \ ## and ##\ \sqrt{2-\sqrt{2+x}\,}\,. \ ## Right?
Dude, I have spent like 2 hours in it and I am really considering to explode this book now. The worst part is this question is at the easy exercises page of the chapter
#%$&(@&*$, I got it! just take x = 2cos(y)
What a relief! But this exercise is at factorizations chapter, I wonder if there is a solution by factoring this monster
Dinheiro said:
Motherf**, I got it! just take x = 2cos(y)
Would you mind sharing your solution? I'm not seeing it.
Ok
x = \sqrt{2+\sqrt{2-\sqrt{2+2cosy}}}
note that
2 + 2cosy = 2(1 + cosy)
and cosy = 2cos²(y/2) -1
so 2 + 2cosy = 4cos²(y/2)
Now, we have
x = \sqrt{2+\sqrt{2-2cos(y/2)}}
analogously 2 - 2 cos(y/2) = 4sin(y/4)
x = \sqrt{2+2sin(y/4)}
Finally, x = 2cos(y/8) <=> 2cos(y) = 2 cos(y/8)
y = 2pi/9
x = 2cos(2pi/9)
xD
By finding all the roots and evaluating them numerically. Alternatively, plot f(x) and x in the range [√2,2]. All eight roots of the polynomial are real, but 7 of them are extraneous to the original problem. All work done in Maple.
My point exactly. Which is why I was confused when Ray said only one real root lies in that interval, I believe there at least need to be two.
I tried that earlier in my attempt. The substitution does yield a 'neat' looking equation, but I don't see how to reach a numerical answer for x without the use of calculators/tables. Could you please share how?
The function ##f(x)## is strictly decreasing on the interval ##[\sqrt{2},2]## (from the derivative), while the function ##x## is strictly increasing on that interval. There is only one root.
That makes sense, thanks Ray.
As a side note, I should start using one of these softwares soon :-p
The expressions of x in the two lines aren't equal. That, or I'm doing some trigonometric errors that are embarrassingly silly. :redface:
After repeatedly squaring, you can simplify out a first-order factor and get an odd -number order polynomial equal to zero.
ehild
At the step
2\cos y = \sqrt{2+2\sin\frac{y}{4}}
squaring and then using the double angle identity
\cos^2\alpha = \frac{1}{2}\left(1+\cos{2\alpha}\right)
yields
\cos{2y} = \sin{\frac{y}{4}}
And I can't proceed.
Mentallic said:
At the step
yields
\cos{2y} = \sin{(\pi/2\pm2y +2k\pi)}=\sin{\frac{y}{4}}
ehild
Of course! :blushing:
