Series Diff EQ problem: (3 - x^2) y'' - (3x) y' - y = 0
  • Thread starter Thread starter VinnyCee
    Diff eq Series
The discussion revolves around solving the differential equation (3 - x^2)y'' - (3x)y' - y = 0. A recursion formula was derived, but the resulting coefficients did not match the expected answer from the textbook. It was suggested that the algebra may be incorrect and that recalculating the coefficients could resolve the discrepancies. Additionally, it was emphasized that the coefficients should not include the powers of x themselves, as they are meant to represent the coefficients of the series expansion. Correcting these issues should lead to a proper solution for y(x).
VinnyCee
The problem (#11, 5.2, boyce diprima):
(3\,-\,x^2)\,y''\,-\,(3\,x)\,y'\,-\,y\,=\,0
I got the recursion formula as:
a_{n\,+\,2}\,=\,\frac{(n\,+\,1)}{3\,(n\,+\,2)}\,a_n
Which give the following results:
\begin{flalign*}<br /> a_2&amp; = \frac{1}{6}\,a_n\,x^2&amp;<br /> a_3&amp; = \frac{2}{9}\,a_n\,x^3&amp;<br /> a_4&amp; = \frac{1}{4}\,a_n\,x^4&amp;\\<br /> a_5&amp; = \frac{4}{15}\,a_n\,x^5&amp;<br /> a_6&amp; = \frac{5}{18}\,a_n\,x^6&amp;<br /> a_7&amp; = \frac{6}{21}\,a_n\,x^7&amp;<br /> \end{flalign*}
When these are used, the answer does not match the book:
y(x)\,=\,a_0\,\left[1\,+\,\frac{x^2}{6}\,+\,\frac{x^4}{24}\,+\,\frac{5}{432}\,x^6\,+\,...\right]\,+\,a_1\,\left[x\,+\,\frac{2}{9}\,x^3\,+\,\frac{8}{135}\,x^5\,+\,\frac{16}{945}\,x^7\,+\,...\right]
What did I do wrong?
Your algebra is a little suspect. Try calculating those coefficients again.
--J
Incorrect recursion table is the trouble...
y(x)\,=\,\sum_{n\,=\,0}^{\infty}\,a_n\,x^n\,=\,a_0\,+\,a_1\,x\,+\,...
\begin{flalign*}a_2&amp; = \frac{1}{6}\,a_0\,x^2&amp;a_3&amp; = \frac{2}{9}\,a_1\,x^3&amp;a_4&amp; = \frac{1}{24}\,a_0\,x^4&amp;\\a_5&amp; = \frac{8}{135}\,a_1\,x^5&amp;a_6&amp; = \frac{5}{432}\,a_0\,x^6&amp;a_7&amp; = \frac{16}{945}\,a_1\,x^7&amp;\end{flalign*}
Also, you shouldn't include the xn in your coefficients. Remember that these are the coefficients of the powers of x! They don't include the power of x themselves. You must multiply them by the appropriate power of x to get your solution. Otherwise, it looks like you're set. Good job.
--J
