Series-Interval of Convergence
  • Thread starter Thread starter 1LastTry
    Convergence
10 replies · 2K views
1LastTry
[itex]\Sigma[/itex] from n=0 to infinity (x-4)^(2n)/((n+1)(11^n))
Find the Radius of Convergence
limit of (Cn/(Cn+1)
Which I found it to be 11 (isn't this supposed to be the Radius of Convergence?)
To find the radius of convergence of a geometric series [itex]\sum_{n=0}^{\infty}a_n[/itex] you take the following limit and solve for x, or an expression involving x.
[tex]a_{n}=\frac{(x-4)^{2n}}{(n+1)11^{n}}[/tex]
[tex]\lim_{n\rightarrow\infty}\left|\frac{a_{n+1}}{a_{n}}\right|<1[/tex]
[tex]\lim_{n\rightarrow\infty}\left|\frac{(x-4)^{2(n+1)}}{(n+2)11^{n+1}}\cdot\frac{(n+1)11^{n}}{(x-4)^{2n}}\right|<1[/tex]
Can you continue from here?
Edit: I inserted the absolute value symbols that I originally forgot.
limit of (Cn/(Cn+1)
Let y = (x-4)^2, and re-write the series.
1LastTry said:
From what u guys said I got ((x-4)^2)/11
Ok, so how does that translate into radius of convergence? Where is |(x-4)^2/11|<1?
1LastTry said:
well i got sqr(-11) +4 < x < 15?
That's pretty wrong. Can you show how you got it??!
well
-1< (x-4)^2/11 < 1 (is this right?)
then i solved that and got to that soltuion. I had a feeling that its wrong since it came out with some weir dnumbers
could it be -7<x<15
1LastTry said:
well
Is there any way how (x-4)^2/11 could be negative? If not, what is the lower limit?
Note that the upper limit (<1) gives two separate limits for x.
could it be -7<x<15
What happens if you set x=14 in the equation above?
O ok, ummm i stil hve to think about this butI guess it can't be negative, sorry I wasnt thinking. I solved it again and would it be 0< eqn < sqrt(11) +4?
Im still kinda confused on how this works, sorry.
