Set of vectors with each subset forming a basis
  • Thread starter Thread starter Constantinos
    Basis Set Vectors
Constantinos
Hey!
Let M and N be two natural numbers and N>M. I want to build a set A with N vectors of size M such that each subset S of A, where |S| = M, contains linearly independent vectors.
Another way to put it is that every S should be a basis for R^M.
Any ideas? Thanks!
Do you want an explicit construction or a proof that such a set exists?
For example, if M= 2, you can take i= <1, 0>, j= <0, 1>, and k= i+ j= <1, 1>. Then any subset of order 2, {i, j}, {i, k}, and {j, k}, is a basis.
For M= 3, start with i= <1, 0, 0>, j=<0, 1, 0>, and k= <0, 0, 1> and add l= i+ j+ k.
Can you continue that?
Thread 'Determine whether ##125## is a unit in ##\mathbb{Z_471}##'
This is the question, I understand the concept, in ##\mathbb{Z_n}## an element is a is a unit if and only if gcd( a,n) =1. My understanding of backwards substitution, ... i have using Euclidean algorithm, ##471 = 3⋅121 + 108## ##121 = 1⋅108 + 13## ##108 =8⋅13+4## ##13=3⋅4+1## ##4=4⋅1+0## using back-substitution, ##1=13-3⋅4## ##=(121-1⋅108)-3(108-8⋅13)## ... ##= 121-(471-3⋅121)-3⋅471+9⋅121+24⋅121-24(471-3⋅121## ##=121-471+3⋅121-3⋅471+9⋅121+24⋅121-24⋅471+72⋅121##...
##\textbf{Exercise 10}:## I came across the following solution online: Questions: 1. When the author states in "that ring (not sure if he is referring to ##R## or ##R/\mathfrak{p}##, but I am guessing the later) ##x_n x_{n+1}=0## for all odd $n$ and ##x_{n+1}## is invertible, so that ##x_n=0##" 2. How does ##x_nx_{n+1}=0## implies that ##x_{n+1}## is invertible and ##x_n=0##. I mean if the quotient ring ##R/\mathfrak{p}## is an integral domain, and ##x_{n+1}## is invertible then...
The following are taken from the two sources, 1) from this online page and the book An Introduction to Module Theory by: Ibrahim Assem, Flavio U. Coelho. In the Abelian Categories chapter in the module theory text on page 157, right after presenting IV.2.21 Definition, the authors states "Image and coimage may or may not exist, but if they do, then they are unique up to isomorphism (because so are kernels and cokernels). Also in the reference url page above, the authors present two...
