Setting up a centrifugal force question
The discussion centers on analyzing the trajectory of a marble positioned in a rotating merry-go-round setup. The marble, initially at rest, is affected by forces including the normal force, fictitious centrifugal force, and Coriolis force due to the rotation. The challenge lies in determining the magnitude of these forces, which is not constant as the marble's radial displacement changes. A rotating frame of reference is essential for solving the problem, requiring a detailed calculus approach to derive the forces' components. Ultimately, understanding these dynamics is crucial for accurately predicting the marble's motion.
rn433
Suppose we have a merry-go-round of radius 10 meters. There's a thin glass tube with cross-sectional density d going radially from the center of the merry-go-round to the edge. In the glass tube one meter away from the center, there's a marble of mass m. The merry-go-round completes one counter-clockwise rotation every 2pi seconds, and the glass tube is frictionless. At time t, the marble is at rest. I want to find the trajectory of the marble.
I'm taking the center of the merry-go-round to be at the origin and the marble's initial position to be at (0, 1); obviously its initial velocity is 0. Since the tube rotates counter-clockwise every 2pi seconds, I can define the marble's position at t as <r(t)cos(t), r(t)sin(t)>. What I'm having trouble with is finding the force acting on the marble. I know the normal force on the marble from the glass tube is in the direction <-sin(t), cos(t)>, perpendicular to the tube. However, I don't know how to determine its magnitude. I initially assumed it was constant, but this leads to an incorrect answer.
It is not constant as the radial displacement of the marble is constantly changing. You have a long exercise in calculus ahead of you, since you can only tell what the tangential and radial components of the force are, and you'll have to work your way up from there to get a function of \theta (r)
I'm pretty sure you can't solve this problem without using the rotating frame of reference, which would mean you have to refer to both the fictitious centrifugal force (Directed radially outwards) and the fictitious Coriolis force (Directed tangentially in the direction of the spin) as well as the real normal force (Directed tangentially against the direction of the spin).
How could I do this, though? I don't know how to determine the magnitude of those forces, either. :(
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
